Intercooler mounting - whats your thoughts
Postby Sideros » Mon Jan 23, 2012 2:23 pm
^ wat?
Sideros
Signwriter
Postby Bling » Mon Jan 23, 2012 2:25 pm
Even with the use of paint, what you're saying makes no sense to me.
Postby FST4RD » Mon Jan 23, 2012 2:37 pm
I think he means get the intercooler as low as possible without it sticking out the bottom of the bumper?
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby hsmidy » Mon Jan 23, 2012 5:16 pm
ive got the same troubble with my ta22(limited space) so ive gone with w2a setup, but definatly keep it hidden if your dead keen on an a2a setup
hsmidy
Postby NOLAW » Mon Jan 23, 2012 5:31 pm
iv heard you still need to run a second radiator with water to air and to me thats just gonna mean im still gonna have to fit that up in there somehow unless theres kits that can run of the one radiator?
as for mounting it lower but "up", where i have it sitting in that second picture is about as low as it will go because if you look closely the holes for the piping go straight in to the engine bay where its sitting there and also the valance has to pull in and if i have it sitting any lower the valence wont pull up and will look f**ked up lol
NOLAW
Postby NOLAW » Thu Jan 26, 2012 7:03 pm
does anyone know if you can run a w2a off a single radiator?
NOLAW
Postby FST4RD » Thu Jan 26, 2012 7:07 pm
You mean from the main radiator?
You could... but I wouldn't think the water would be near cold enough.
FST4RD
Postby CelicaGT8 » Thu Jan 26, 2012 8:44 pm
Where it is in the second pic is mint!
CelicaGT8
Postby iOnic » Thu Jan 26, 2012 8:48 pm
You can run it off the main radiator but the air going into your engine will be the temperature of your heater on hot.
W2A heat exchangers dont have to be big. Mine is smaller than your IC and a lot thinner.
Postby NOLAW » Thu Jan 26, 2012 8:59 pm
have you got any details on your kit/setup iOnic?
NOLAW
Postby iOnic » Thu Jan 26, 2012 9:07 pm
Just stock Subaru stuff. It's only on my baby dick Corolla. The heat exchanger is about the size of an aircon condenser. If you already have money in a FMIC setup then use that otherwise I woulld build a W2A setup around a heat exchanger that suits your space.
Postby stolic » Thu Jan 26, 2012 9:13 pm
hsmidy wrote:ive got the same troubble with my ta22...
Pics plz 8)
I used to have an RS legacy.. from what I remember the w2a rad in the front wasn't huge ie thinner than an intercooler for sure. So you could make it fit, but then you have the added weight, complexity and imo ugly of the w2a setup..
I say whip out the dremel or what have you, and carefully reshape your grill. When done nicely it will look like it was supposed to be there... unless you want you car to look like this
jj :lol:
ImageTA22-build - TA22-blah
I envy those with little interest in cars, for they have money and spare time.
stolic
