Al wrote:How do you measure the engine hp without pulling the engine out and putting it on an engine dyno?
Last time I checked I drove on wheels not a flywheel.
RedMist wrote:Al wrote:How do you measure the engine hp without pulling the engine out and putting it on an engine dyno?
WHP is what matters!
That WHP is considerably better than I had expected from a CT20b. It's more than I'm pulling from my GT2871r's.
I suspect a good portion of the power is the E85.
cat007 wrote:Al wrote:How do you measure the engine hp without pulling the engine out and putting it on an engine dyno?
They let it run down after a high gear pull and measure the resistive force it takes to slow the dyno down?
iOnic wrote:What's the obsession with flywheel power anyway? I'm personally more interested in the sum of all parts.
strx7 wrote:iOnic wrote:What's the obsession with flywheel power anyway? I'm personally more interested in the sum of all parts.
flywheel HP is the only TRUE HP, because all types of hub and wheel dynos read different!!!!!! why cant people comprehend that.
wheel HP readings are only relevant from one car to another is they are done on the same dyno, or within a ballpark if it is the same type of dyno.
many years ago a vehicle was run on dynojet, dyno dynamics and dynopak dynos as an auto. the owner then converted it to manul, and ran all 3 dynos again. before the engine was put in the car it was also run on an engine dyno. the results were....
Dyno Pak manual read 9% less than flywheel
Dynopak Auto read 11% less than flywheel
Dynojet Manual read 15% less than flywheel
Dynojet Auto read 17% than flywheel
Dyno Dynamics Manual read 27% less than flywheel
Dyno Dnamics Auto read 29% Less than flywheel.
strx7 wrote:about 550-600hp at the motor from memory
was a 5.something litre v8
