rx7 calipers
rx7 calipers
Postby Lurkin » Mon Jan 23, 2012 11:46 pm
A while back when I still had an ae101 it was recommended to upgrade to rx7 (s4 I think) brakes..
tried to find the original thread without luck.
Anyway, planning an ae71 build here in Melbourne and thinking of using AJPS adapters/ ae86 hubs + struts, making it a bolt onish upgrade.
However, AJPS's site doesnt recommend a series of caliper, just says that FC RX7 or FD RX7 is ok.
Does the series matter? is there much/ any difference between them?
Past casualties
1986 4age liftback (sold)
1985 4age aw11 (well crunched)
1993 ae101 gt apex levin (sold)
Lurkin
Postby strx7 » Tue Jan 24, 2012 9:27 am
basially the same caliper, if there is anything different about them it would only be in the mounting points.
Postby hsmidy » Tue Jan 24, 2012 6:45 pm
id use the s4/s5 (fc) calipers as the s6 are a bit bigger and when you have smaller wheels it can cause issues, I have that same setup on my TA22 .
hsmidy
Postby Lurkin » Tue Jan 24, 2012 10:30 pm
strx7 - do you have any s4/5 at partsworld? if you do, could you pm me pricing including postage to kilbirnie?
Emailing AJPS now to make sure these are sweet with their adapters.
Past casualties
Lurkin
Postby mjrstar » Wed Jan 25, 2012 8:48 am
I was under the impression that the s4 was a cast iron caliper and the later ones were aluminium
Could be wrong though...
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby strx7 » Wed Jan 25, 2012 9:19 am
all S4/5/6/7 rx7 4pots are alloy.
we dont have any at work, best to grab them off trade me.
i do have the templates for fc 4pot + 280mm S13 disc onto AE101 hub.
Postby Lurkin » Thu Jan 26, 2012 12:22 am
Any ideas whether these (and tools) would be ok a suitcase going back to Australia? they aren't on the airlines 'dangerous/ hazardous/ banned' list?
Past casualties
Lurkin
Postby Soiled » Thu Jan 26, 2012 5:53 am
Suitcase fine, hand luggage not so much just due to there size and weight could be seen as a weapon.
Soiled
Postby Lurkin » Thu Jan 26, 2012 12:16 pm
Sweet, I read the Aussie quarantine/ customs site and seems they are interested in anything related to food or dirt. So if they are sparkling clean, should be fine.
Any suggestions on rear brakes? 4 pot fronts with drums on the rear probably isnt the best....
Past casualties
Lurkin
Postby TRD Man » Thu Jan 26, 2012 12:47 pm
S6 & 7 Front calipers are lighter than S4 & 5.
Altezza 2 pot rears are a nice caliper which should work in your application.
TRD Man
Postby Lurkin » Thu Jan 26, 2012 4:23 pm
and they are about the same price!
any recommendations on ways to clean them? I spy brake cleaner on supercheapauto.co.nz but is it really any different to degreaser?
Past casualties
Lurkin
Postby Dell'Orto » Thu Jan 26, 2012 6:19 pm
Brake cleaner dries off better than degreaser, its not so oily.
