Brownie points for who can tell me
Is in a 3sgte sw20 incase the boot didnt give it away haha
James
QikStarlie wrote:isnt a g3. its either a g1 or possibly a g2 as the used same case, but from memory they had a serial plug? not the ribbon style. moneys on a g1. as matt says the sicker on the end will tell you what it is.
should be laptop tuneable being a linkplus though.
you could get those loom adaptor things for the early g1 links.
QikStarlie wrote:isnt a g3. its either a g1 or possibly a g2(not very common) as the used same case, but from memory they had a serial plug? not the ribbon style. moneys on a g1. as matt says the sicker on the end will tell you what it is.
matt dunn wrote:QikStarlie wrote:isnt a g3. its either a g1 or possibly a g2(not very common) as the used same case, but from memory they had a serial plug? not the ribbon style. moneys on a g1. as matt says the sicker on the end will tell you what it is.
Correct, it will be a G1 definatly,
as I have done a fair bit with a Linkplug G2 and they do have a serial plug,
not the one in the picture.
So runs the oldest software, and is not upgradeable, but will be laptop compatable.
Users browsing this forum: Bing [Bot], Google [Bot] and 5 guests
