What is this box hanging of my new link plus..
Postby headshotnz » Sun Jan 29, 2012 9:03 pm
would like to know :)
Brownie points for who can tell me :)
Is in a 3sgte sw20 incase the boot didnt give it away haha
James
Current: UCF20 NZ New LS400,
(Current project) Gen II SW20 Turbo (MR2 v0.5Beta currently in the works)
Previous: Ae101 trueno (S/S), ST185 Group A, Accord with adjustables and H22a certed. SW20 (ct20b, blitz ecu) Uzz30, ae101 s/s 20v c56(-04c;) ) lsd, ae100 beast 5afe(for maximum horsepowers)
headshotnz
Postby Adoom » Sun Jan 29, 2012 9:10 pm
Really crap pic isn't helping.... :roll:
From that angle, it looks like it could be a loom adapter? :?:
Adoom
Postby headshotnz » Sun Jan 29, 2012 9:17 pm
Yeah sorry about that.. its the only picture iv got from the current owner, i dont currently have it in my possesion yet
headshotnz
Postby Dell'Orto » Sun Jan 29, 2012 9:32 pm
Yeah it does look like an adaptor...didnt know they made them for LinkPlus. Definitely looks like the standard ECU plugs are going into it though
Postby iOnic » Sun Jan 29, 2012 9:42 pm
Postby headshotnz » Sun Jan 29, 2012 10:41 pm
headshotnz
Postby headshotnz » Mon Feb 06, 2012 7:37 am
Just got told thats theres a couple of versions of the link plus, one you must use a hand controller to tune 8O and one a laptop..
I dont suppose any one can tell the difference from the photo?
If its the hand controller version. Will be straight on TM $1 reserve, swapping for a G4.
headshotnz
Postby ON PSI » Mon Feb 06, 2012 9:05 am
the easy way is to ring link with the serial number on it
ON PSI
Postby iOnic » Mon Feb 06, 2012 9:41 am
If that is definitely an Adaptalink then the ECU is laptop tunable. Adaptalinks were only used on G3's which are all Laptop Tunable. The last hand controller only ECU was the G1 Version 3.
Postby matt dunn » Mon Feb 06, 2012 2:17 pm
The sticker that you can see on the side beside the tuning port will have version numbers on it.
Probably something like LPV14 or similar.
post them up when you get it and we will be able to tell you what it is and if it is laptop tuneable or not.
99% of the linkplus ecu's were.
Postby headshotnz » Mon Feb 06, 2012 3:20 pm
thanks ionic and matt!
looking at this website then
http://www.linkecu.com/products/engine- ... escription
It probably is a link g3.
On that note, ill porbably be getting speedtech to tune it (after i save a million dollars ha!)
Am i missing any thing important from a g4 by going g3?
Ill be running a 3sgte with a basic t3t4 setup.
Fuel pump, injectors etc etc are to be desided upon building engine.
headshotnz
Postby QikStarlie » Mon Feb 06, 2012 3:38 pm
isnt a g3. its either a g1 or possibly a g2(not very common) as the used same case, but from memory they had a serial plug? not the ribbon style. moneys on a g1. as matt says the sicker on the end will tell you what it is.
should be laptop tuneable being a linkplus though.
you could get those loom adaptor things for the early g1 links.
QikStarlie
Postby headshotnz » Mon Feb 06, 2012 3:41 pm
QikStarlie wrote:isnt a g3. its either a g1 or possibly a g2 as the used same case, but from memory they had a serial plug? not the ribbon style. moneys on a g1. as matt says the sicker on the end will tell you what it is.
Damn, i was happy with a G3 :( Will have to wait untill i get it in my hands
headshotnz
Postby iOnic » Mon Feb 06, 2012 3:45 pm
Didn't know that :lol: I stand corrected.
Postby Dell'Orto » Mon Feb 06, 2012 3:59 pm
You clearly didnt watch High Octane enough :P
Postby iOnic » Mon Feb 06, 2012 4:33 pm
^ Not sure if bad thing :lol:
Postby matt dunn » Mon Feb 06, 2012 6:08 pm
QikStarlie wrote:isnt a g3. its either a g1 or possibly a g2(not very common) as the used same case, but from memory they had a serial plug? not the ribbon style. moneys on a g1. as matt says the sicker on the end will tell you what it is.
Correct, it will be a G1 definatly,
as I have done a fair bit with a Linkplug G2 and they do have a serial plug,
not the one in the picture.
So runs the oldest software, and is not upgradeable, but will be laptop compatable.
Postby headshotnz » Mon Feb 06, 2012 6:37 pm
Hmm, Matt Dunn, I believe your Mr. Experience.
For a basic gen 2 3sgte t3t4 setup, with standered internals (bar gen 3 cams, ARP headstuds and a steal gasket), plus what ever fuel upgrades i need. On a daily street car, will the g1 sufice, or am i missing out on some thing special with a g4. I am rather new to this side of things. Bearing in mind, I will be getting speedtech to tune the ecu.
headshotnz
Postby matt dunn » Mon Feb 06, 2012 7:04 pm
Best thing to do is always ask the person that will be doing the tune.
Postby QikStarlie » Mon Feb 06, 2012 7:07 pm
will be fine. was running 11's in my old gt starlet, using G1 link plus (v14) drove pretty much spot on, on the road also.
speedtech will probably have a cry and try sell you a g4. but the ecu will run it fine even though its older tech..
QikStarlie
