Can anyone advise where to get a head gasket made?
I was just going to take an old one to Prometal and have it laser cut out of 1.2mm copper but they need a cad file for that which would make it a very costly exercise.
Crown wrote:Can anyone advise where to get a head gasket made?
wde_bdy wrote:Decreasing compression for boosted applications is the common reason for a 1.2mm copper gasket.
Callum
sergei wrote:wde_bdy wrote:Decreasing compression for boosted applications is the common reason for a 1.2mm copper gasket.
Callum
This actually a misleading application, as decreasing compression by thicker head gasket does not reduce detonation as much as people think (in some cases it makes it worse).
If the block and head was skimmed, you might want to use thicker head gasket.
