Al wrote:If you haven't done it before around four hours and it should be on the deck.
Its usually takes less time to put the engine back than taking it out for some reason
Spark plugs and oil filter? I can do both of those in 20 minutes with the motor in place, they are possibly the easiest jobs in a sw20.
Ok so you are taking the head off. So you may as well do cambelt, waterpump, thermostat, tensioner, idlers, cam shaft seals, crankshaft seal, valve cover gasket, alt belt, a/c belt.
Al wrote:If owners of MR2s actually had some money there could be a good business opportunity. Sadly
Including mounting the gearbox twiceAkane wrote:takes me 3 years.
Buy engine, leave it outside in the rain for 2 years and 11 months.
Forced to move house, ask chalkie to give me a hand and slot the damn thing in within a day.
Akane wrote: ask chalkie to give me a hand and slot the damn thing in within a day.
Users browsing this forum: Majestic-12 [Bot] and 11 guests
