Rust killing products.. what works?
Postby christopher j » Fri Feb 10, 2012 8:56 am
cat007 wrote:
BZG|Bling wrote:Read the safety sheets they should supply with the POR15, the fumes are pretty bad, so don't do it in a closed garage etc.
Yeah it's a resin based product so think of it like fibreglass resin fumes.
Isocyanates too if i recall correctly. Be carefull.
And wash it off your skin immediately if you get any on. Otherwise its there untill it wears off. Which is a long time.
christopher j
Postby Adoom » Fri Feb 10, 2012 9:50 am
I think you have to have a lot of exposure to it over a long time to have problems with isocyanates..... unless you are spraying it :?
Adoom
Postby Bling » Fri Feb 10, 2012 2:22 pm
Either way, ANY exposure is a bad thing. Yep long term exposure will be worse. Was just saying to not use it in an enclosed area. Ventilation ftw.
Postby hsmidy » Fri Feb 10, 2012 10:01 pm
little bit off topic but once yourve treated an area with rust kill, if you had a pin hole or two can you just mig straight over top of it?? or do you need to do all your welding prior to treating?
hsmidy
Postby TRD Man » Mon Feb 13, 2012 12:49 pm
I have used a tergo product called Rust Killer. Works well.
TRD Man
Postby Bling » Mon Feb 13, 2012 1:16 pm
Try more coats if you have small pin holes. I have never welded next to it to know what it does with heat but i'd paint it last. You could always add a bit of filler between coats.
