blocking up dizzy hole on blacktop head
Postby NOLAW » Mon Feb 20, 2012 6:06 pm
hey guys
iv put up a picture of what im talking about, this is a RWD 7agte with a 20v blacktop head, i hhave very minimal romo between the back of the head and firewall so im wondering if i can just put i plug of somesort in this as im running coil packs
morgz
NOLAW
Postby Dell'Orto » Mon Feb 20, 2012 6:10 pm
Heaps of RTV :lol:
Nah, just whack a frostplug in there.
Postby crispy'86 » Mon Feb 20, 2012 7:35 pm
Frost plug suggestion here too, good idea for the housing on the back of the head too
crispy'86
Postby Bazda » Mon Feb 20, 2012 9:08 pm
The stock dizzy wont work??
Its pretty slim once you take off all the guts.
Postby Lloyd » Mon Feb 20, 2012 9:11 pm
As Bazda says, just take the cap and rotor etc out and its the perfect plug.
Postby KinLoud » Tue Feb 21, 2012 12:24 pm
i presume you're using the 7afe crank angle sensor?
Postby NOLAW » Tue Feb 21, 2012 9:10 pm
yeah iv got one of bazdas caps but im thinking its still gonna hit the firewall so im just exploring other options incase it does when it comes to mounting the engine
kinloud, wheres the CAS located on the 7afe?
NOLAW
Postby matt dunn » Tue Feb 21, 2012 10:12 pm
What are you going to use for crank and cam sensors without the dist?
Postby NOLAW » Wed Feb 22, 2012 5:16 pm
well is there a alternative option i can do for my crank and cam sensors? as i really dont want to go hacking into my painted firewall?
NOLAW
Postby iOnic » Wed Feb 22, 2012 6:51 pm
Fit a missing tooth wheel to crank pulley with reluctor pickup sensor and you're away laughing. Sub $200 for both from Link IIRC
Postby NOLAW » Wed Feb 22, 2012 7:22 pm
got a link to that man? what do you mean by the missing tooth crank pulley? cheers
NOLAW
Postby QikStarlie » Wed Feb 22, 2012 7:39 pm
QikStarlie
Postby NOLAW » Wed Feb 22, 2012 7:56 pm
sounds like a bit of me im thinking, anyone else had any experience with these?
NOLAW
Postby QikStarlie » Wed Feb 22, 2012 10:02 pm
you'l obliviously need to mount a sensor (vr) as well.
will depend on what ecu and ignition / injection setup your going to run. if you will get away with a single missing tooth trigger wheel like those. will do dizzy, wasted spark, but not coil on plug from memory. i could be wrong here, probably best to talk to link if thats what your going to run
QikStarlie
Postby matt dunn » Wed Feb 22, 2012 10:39 pm
QikStarlie wrote:you'l obliviously need to mount a sensor (vr) as well.
Correct, you cannot do coil on plug properly without a cam signal,
as there is no way for the ECU to tell the difference between compression and exhaust stroke.
Postby RomanV » Wed Feb 22, 2012 11:14 pm
Unless you have wasted spark and batch fired injectors I guess?
Oh... you said 'properly' :lol:
8)
Users browsing this forum: No registered users and 38 guests
