True-No-Turbo wrote:Scan tool will take away the guess work.
Soiled wrote:As it is dies can you put the clutch in and pump the throttle to try keep it alive?
Also cleaning the entire intake not just the throttlebody could be helpful as the breather pipe makes a mess of everything.
How long has it been since your last oil change?
