Resealing a turbo
Resealing a turbo
Postby Stott69 » Thu Mar 01, 2012 6:07 am
Im asuming by the fact that after a while of not driving the car, it will puff white smoke on start up. How much is dependent on how long since I last drove the car. S o is it worth finding new seals and pulling the turbo apart or should I just save up for a new turbo all together?
Im currently running a DSR430 Gen1 with internal gate on a 2jzgte.
Stott69
Postby Shrike » Thu Mar 01, 2012 8:27 am
i have the same turbo on my skyline they are common to have the rear seal let go and no you cant get a rebuild or seal kit trust me ive looked
best bet would be get a new turbo
Something genuine ie garrett, borg warner etc
ill be getting a borg for both the levin and skyline when money allows as there a good price (around a grand delivered)
http://www.theboostlab.com/store/catego ... rg-Warner/
look at the s series also email them for better pricing ive had my workmate buy one from these guys no issue :)
Shrike
Postby Mr Ree » Thu Mar 01, 2012 10:22 am
Are you sure it isnt leaking valve stem seals guys?
If the turbo seals are leaking, you will notice it smoking while driving it as well, not just on start up.
wak thud gush!
Mr Ree
Postby solitaire » Thu Mar 01, 2012 10:44 am
Mr Ree wrote:Are you sure it isnt leaking valve stem seals guys?
My exhaust side oil seals were rooted on my turbo and it only did it at start up
AE92, KZJ120, KDJ120
solitaire
Postby Mr Ree » Thu Mar 01, 2012 11:00 am
Maybe it seeps oil when it gets cold and the metal shrinks, then the thermal expansion of the metal when its heated up is enough to stop the seepage?
When an oil seal on a turbo is properly FUBAR, it will smoke like a chimney
wak thud gush!
Mr Ree
Postby solitaire » Thu Mar 01, 2012 11:01 am
Mr Ree wrote:Maybe it seeps oil when it gets cold and the metal shrinks, then the thermal expansion of the metal when its heated up is enough to stop the seepage?
Maybe, i got the distinct impression it was oil in the exhaust burning off as the exhaust heated up
Also chris at alltech said they "were a bit rough and could use replacing" not "they are rooted"... so your theory above holds...
solitaire
Postby Stott69 » Thu Mar 01, 2012 5:20 pm
how hard are valve steam seals to do? And what is the easyist way to confirm or bust either problem?
Stott69
Postby Mr Ree » Thu Mar 01, 2012 7:04 pm
You can do the valve stem seals in a day if you know what you are doing, and have all the tools you will need. The TSRM really helps when doing stuff like this :)
I would inspect the turbo to see if there is obvious signs of oil leaking into the turbine housing, and check out the intercooler tract for oil too. If both of those are good, then I would pick your VSS are the culprits.
wak thud gush!
Mr Ree
Postby mazdahard » Thu Mar 01, 2012 9:43 pm
another way to check for valve stem seals too is go down a hill in gear (the lower gear the better) dont touch the gas all the way down and stomp on the gas at the other end if it lets out a big puff then yeah valve stem seals are naffd
mazdahard
Postby Stott69 » Fri Mar 02, 2012 8:00 pm
mazdahard wrote:another way to check for valve stem seals too is go down a hill in gear (the lower gear the better) dont touch the gas all the way down and stomp on the gas at the other end if it lets out a big puff then yeah valve stem seals are naffd
Tryed this going down wainui hill, couldnt see any smoke coming from the back at the bottom
Stott69
Postby mazdahard » Sat Mar 03, 2012 11:56 pm
might not be your problem then if it doent annoy you that much just leave it and keep an eye on the oil level
mazdahard
Postby gt4dude » Sun Mar 04, 2012 6:09 am
itll smoke fulltime later trust me...
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby DVSMOTORSPORT » Sun Mar 04, 2012 10:44 am
Initial post says white smoke, but everyone is talking about oil.
Is it white smoke, or does it have a blue tinge to it?
Hi Im Ben, Have a nice day :)
DVSMOTORSPORT
Postby sergei » Sun Mar 04, 2012 11:56 am
DVSMOTORSPORT wrote:Initial post says white smoke, but everyone is talking about oil.
oil will white smoke under right conditions ( if its introduced after combustion).
Postby DVSMOTORSPORT » Sun Mar 04, 2012 6:52 pm
Cant say Ive ever seen oil burn white in my 14 years of being a mecahnic, but we learn things everyday, Id just need to see it to believe it.
DVSMOTORSPORT
Postby evil_si » Sun Mar 04, 2012 6:59 pm
Very common ben.
Seen it Plenty of times,
Very common when exhaust side turbo oil ring go's, or turbo shaft snaps and turbine exits the housing :D
evil_si
Postby gt4dude » Sun Mar 04, 2012 7:09 pm
200AWKW / 370NM
gt4dude
Postby sergei » Sun Mar 04, 2012 8:31 pm
DVSMOTORSPORT wrote:Cant say Ive ever seen oil burn white in my 14 years of being a mecahnic, but we learn things everyday, Id just need to see it to believe it.
Drip oil on hot surface (exhaust manifold), see what colour it is....
Postby Stott69 » Mon Mar 05, 2012 5:47 am
Yea Its white smoke, no blue in there.
Stott69
Postby Quint » Mon Mar 05, 2012 9:26 am
It's definitely turbo imo. rebuilt the head on my 1g when it had leaky valve stems (threw a cam) which stopped it smoking on start-up. Later blew some seal in the turbos and it bellowed white smoke at high boost (ct12s don't handle 20psi O_o) and still chuffed a bit afterwards at lower levels.
Quint
Users browsing this forum: No registered users and 32 guests
