My exhaust side oil seals were rooted on my turbo and it only did it at start upMr Ree wrote:Are you sure it isnt leaking valve stem seals guys?
If the turbo seals are leaking, you will notice it smoking while driving it as well, not just on start up.
Maybe, i got the distinct impression it was oil in the exhaust burning off as the exhaust heated upMr Ree wrote:Maybe it seeps oil when it gets cold and the metal shrinks, then the thermal expansion of the metal when its heated up is enough to stop the seepage?
When an oil seal on a turbo is properly FUBAR, it will smoke like a chimney
mazdahard wrote:another way to check for valve stem seals too is go down a hill in gear (the lower gear the better) dont touch the gas all the way down and stomp on the gas at the other end if it lets out a big puff then yeah valve stem seals are naffd
DVSMOTORSPORT wrote:Initial post says white smoke, but everyone is talking about oil.
Is it white smoke, or does it have a blue tinge to it?
DVSMOTORSPORT wrote:Cant say Ive ever seen oil burn white in my 14 years of being a mecahnic, but we learn things everyday, Id just need to see it to believe it.
