20 valve blacktop ecu. Manual or auto
Postby point2 » Thu Mar 15, 2012 7:07 pm
Hi all
I have purchased a AE82 with a silver top 20v
It came with a bunch is spares including 2 blacktops and enough to build another silver top.
In the interim while I build one good BT /ST hybrid donk, I want to run the ST on ITB's without the AFM.
I am to collect a BT loom this weekend along with a BT auto ecu.
Note I also have a manual BT ecu that came as part of spares collection.
My question is this.
On the auto ecu What do you do to pin 22 on the 22 pin plug that is NSW?
Neutral start switch
Do you need to trick this setting?
I'm told auto revs to 8200 where manual Revs to 7800
Is the above accurate info?
Could have would have should have searched for more info, but feel it easier to ask those in the know.
Mike c
In the build process
Dreams are free
Motorsport however is not.
point2
Postby RobertC » Thu Mar 15, 2012 7:23 pm
have little to add here apart from that the manual will also rev to ~8200.
MRAE111 wrote:ok thanks guys but wen u dont have trmpets i think the air flow quickeer into the throttle bodies
RobertC
Re: 20 valve blacktop ecu. Manual or auto
Postby Bling » Thu Mar 15, 2012 7:57 pm
point2 wrote:Could have would have should have searched for more info, but feel it easier to ask those in the know.
On the contrary, a quick use of the search function is easier than writing a post. Also a lot quicker but each to their own. All covered many many times. Try a search and see what you find :wink:
Postby point2 » Thu Mar 15, 2012 7:57 pm
Ok, well that's good news.
Are all ecus the same. All manuals have the same maps?
Mine seems to be running rich at moment under full load, so am wondering if blacktop ITB's have already been added.
As another question, what are others getting from a tank of gas on a ST motor
My tank is 45 litres and I'm getting about 400-450ks
So 10l per 100ks
Dreams are free
point2
Postby point2 » Thu Mar 15, 2012 8:01 pm
To true there Mod
I did try using sites search function, but came up with few direct answers.
Dreams are free
point2
Postby Dell'Orto » Thu Mar 15, 2012 9:29 pm
All I've read is that an auto blacktop ECU will idle higher than a manual ECU with a manual box...never seen proof of this though.
Silvertops do run pretty rich, but 10l/100k is pretty rough...I tend to get 500ish k's to 45l combined town/open road. Is the o2 sensor hooked up?
Postby point2 » Thu Mar 15, 2012 9:32 pm
Dell'Orto wrote:All I've read is that an auto blacktop ECU will idle higher than a manual ECU with a manual box...never seen proof of this though.
Good question and worth checking
Will check tomorrow
Mc
Dreams are free
point2
Postby Bling » Thu Mar 15, 2012 11:28 pm
I get that mileage and the car spends most of it's life warming up :oops: . So to be expected. Get much better on long trips. So if it's short trips it's probably about right.
Postby gepsk8 » Fri Mar 16, 2012 12:33 am
hey, how much for silvertop loom and ecu when ur done?
O272754663
gepsk8
Postby point2 » Sun Mar 18, 2012 9:17 am
No 02 sensor on this car.
Might explain a little over fuelling
Dreams are free
point2
Postby Lurkin » Sun Mar 18, 2012 10:11 am
Hey Point2
Could be interested in purchasing:
BT both cam wheels
vvt solinoid
TPS
2x cam bolts (the shorter of the two types)
distributor
BT Rocker/sparkplug/cam covers
let me know what you've got? pm me prices if you would like to sell any of the above.
Past casualties
1986 4age liftback (sold)
1985 4age aw11 (well crunched)
1993 ae101 gt apex levin (sold)
Lurkin
Postby point2 » Sun Mar 18, 2012 11:23 am
Hey all.
No parts for sale yet other than a silver top head with itbs.
Dreams are free
point2
Postby magweal » Tue Mar 20, 2012 8:26 pm
Hi there I'm running a BT with a Auto loom Man ECU, ther are 2 wires that I didnt conect to the ECU I'll check, I also have the pin put for both auto and man BT ECU I'll see if I can dig them out
98 BZ-T rola SMUGLN V1(RIP)
97 NZ new GL rola now with BZ transfer 80%
magweal
Postby point2 » Tue Mar 20, 2012 8:49 pm
Cheers, any info handy
Dreams are free
point2
Postby magweal » Tue Mar 20, 2012 8:55 pm
Where abouts are you, if your out west pop on round
magweal
Users browsing this forum: No registered users and 34 guests
