New camber rules for certs
Postby holden_fan2005 » Fri May 18, 2012 12:16 am
iOnic wrote:Half a degree outside of stock spec is bugger all.
A few whales in the back of a serena can get more than 1/2 a degree on the back wheel!!
holden_fan2005
Postby tsoob » Fri May 18, 2012 9:27 am
siren676 wrote:hands up whos car is now illegal :x
Hands up if you just don't give a shit.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby duddley » Fri May 18, 2012 9:36 am
What happens if your car gets written off and insurance tells you your not covered due to your not being legally on the road? I'm pretty sure you will give a shit then.
i don't club seals..... only sandwiches
duddley
Postby GTCRSHR » Fri May 18, 2012 9:55 am
holden_fan2005 wrote:A few whales in the back of a serena can get more than 1/2 a degree on the back wheel!!
you need to change the type of women you go for
Nothing to see here ...
GTCRSHR
Postby tsoob » Fri May 18, 2012 9:58 am
this is borrowed from another forum..
reading the LVVTA info sheet as 04/2012 there are a few ways around it.
1. if your car is primarily used for motorsport and you have a current LVV Authority Card you are exempt.
2. if you can prove that your vehicle still meets the following standards 2.2(2)(a), 2.3(8) and 2.4(1). this is covered off in the info sheet. This is still all a guideline and is subject to change in the future (trial period currently)
overall i dont think this is necessarily a bad thing. Gives the LVV certifiers some black and white for certing vehicles but still allows others to get through as long as you can prove its still safe (road and brake performance test)
i do however think its pretty gay that you have to supply an alignment check sheet thats no older than 14days.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby wde_bdy » Fri May 18, 2012 10:20 am
They have read it wrong, the road and brake tests apply for the 1/2 degree window outside manufacturers tolerance. Inside manufacturers tolerance they are not required, outside tolerance + 0.5 is motorsport only.
Callum
wde_bdy
Postby iOnic » Fri May 18, 2012 10:55 am
The way I look at it, there should be one rule for all. If lil Johnny's Cefiro on BC coilovers with -3deg camber is deemed unsafe for the road, the same car should also be unsafe for road use if it is used for motorsport. Let's face it, the idiots that this rule is targeting don't have certs anyway so it doesn't bother them. What is stopping people from having excessive camber angles without installing mods (coilovers etc) that require certification? I could quite easily run stupid camber on the evolution and since it only has lowering springs, it would be perfectly legal.
Postby tsoob » Fri May 18, 2012 11:09 am
iOnic wrote:The way I look at it, there should be one rule for all. If lil Johnny's Cefiro on BC coilovers with -3deg camber is deemed unsafe for the road, the same car should also be unsafe for road use if it is used for motorsport. Let's face it, the idiots that this rule is targeting don't have certs anyway so it doesn't bother them. What is stopping people from having excessive camber angles without installing mods (coilovers etc) that require certification? I could quite easily run stupid camber on the evolution and since it only has lowering springs, it would be perfectly legal.
this is my point, its not really that well thought out, and its just going to lead to more and more people not bothering, it will also discredit the lvv system
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby Snoozin » Fri May 18, 2012 11:30 am
I blame IRS for this problem.
If everyone had solid axles then everything would be super.
Snoozin
Postby tsoob » Fri May 18, 2012 12:15 pm
The thing that gets me, is why they $&#$% dont they put some energy into the fact that 1000's of cars on the road have decent shocks, 2 zze corollas with 100k on them this week alone with all 4 shocks rooted.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby GTTpower » Fri May 18, 2012 12:36 pm
Out of interest, where do people find these factory specs for camber tolerance?
1999 SXE10 Altezza RS200Z
2004 Honda SCV100
Steam/Origin ID: nzEP85
GTTpower
Postby wde_bdy » Fri May 18, 2012 12:43 pm
I asked my wheel allignment guy for a printout, apparently it can vary from machine to machine and they could make it read whatever I needed it to while doing the alignment. Not really the approach I wanted to take though.
Callum
wde_bdy
Postby Snoozin » Fri May 18, 2012 4:57 pm
wde_bdy wrote:I asked my wheel allignment guy for a printout, apparently it can vary from machine to machine and they could make it read whatever I needed it to while doing the alignment. Not really the approach I wanted to take though.
Callum
Snoozin
Postby Bling » Fri May 18, 2012 5:32 pm
Lol, I can understand it being frustrating, but surely condoning people don't give a shit about their cars being legal or not isn't ideal either. Especially with your businesses field of work.
Postby d1 mule » Fri May 18, 2012 6:27 pm
Having these laws is $&#$% him also tho.
big gay tires on 8" + rims, cant put dope kings springs in lil johnnys ceffy cuz rear will slamber out to much etc etc.
its just the old hot rod boys in the LVV being stuck in the past as per usual
d1 mule
Postby wde_bdy » Fri May 18, 2012 6:45 pm
The reply I got on the cert forum was it was the certifiers asking for limits so they could reject some of the rubbish coming through, personally I think they should have just set a reasonable limit like 1 or 1.5 degrees negative (don't really need any more on the road) with the only way to exceed that as manufacturers tolerance specs + 0.5 degrees or motorsport use.
Callum
wde_bdy
Postby Bling » Fri May 18, 2012 7:32 pm
d1 mule wrote:Having these laws is $&#$% him also tho.
I doubt lil johnny is going to be certing his ride though, bay. :lol:
Postby Garreth27 » Fri May 18, 2012 7:39 pm
poor lil johnny, being used as bad example 24/7 :lol:
Current Rides:
91 Gt Starlet - Forged 5efte Drag Toy
88 EP71 Turbo S Starlet Track Toy
99 SEX10 Altezza - Daily Driver
Garreth27
Postby iOnic » Fri May 18, 2012 7:44 pm
Postby Garreth27 » Fri May 18, 2012 8:21 pm
yep seen it b4, least he made a name for himself haha
Current Rides:
Garreth27
Users browsing this forum: Bing [Bot] and 23 guests
