Bazda wrote:I just use the alarm bonnet pin switches from Jaycar.
l1ttle_d3vil wrote:Other end of the switch can be wired in to anything, earth or 12v, just as long as it switches at the exact point the clutch engages/disengages so the ECU can recognise the change. If it switches too early, the car is trying to move while the ECU is still limiting the revs for launch control...
Dell'Orto wrote:You've tried this type?
Both Jaycar and Dick Smith do various versions of these
Users browsing this forum: Majestic-12 [Bot] and 27 guests
