Mr2 turbo boost problem
Postby headshotnz » Sat May 26, 2012 10:57 am
Trying to figure out some problems.
Spec:
CT20b
Standered injectors
Blitz ECU
3 inch downpipe
rebuilt engine
The rest is standered.
The blitz ecu it was running 17 psi, one day i woke up and it was only running 9psi.
Spool time hasn't changed, its very consistent all the way too redline.
I cant hear any boost looks.
and vacuum is at normal 20ish at idle.
Any suggestions would be awesome.
If it means any thing there is also large amounts of blowby, (oil coming out of the intake)
Ta
James
Current: UCF20 NZ New LS400,
(Current project) Gen II SW20 Turbo (MR2 v0.5Beta currently in the works)
Previous: Ae101 trueno (S/S), ST185 Group A, Accord with adjustables and H22a certed. SW20 (ct20b, blitz ecu) Uzz30, ae101 s/s 20v c56(-04c;) ) lsd, ae100 beast 5afe(for maximum horsepowers)
headshotnz
Postby steroidcontaskie » Sat May 26, 2012 7:49 pm
Hmmm, no responses eh.
Well, I am super noob, but I could give it a go.
have you got a boost controller? could it have failed? Doesnt the CT20B have like a 10PSI internal wastegates spring?
Just a thought.
Edward
Science never sleeps...
RVR Turbo (idle)
steroidcontaskie
Postby Akane » Sat May 26, 2012 8:11 pm
limp mode brah.
Postby headshotnz » Sat May 26, 2012 9:27 pm
No boost controller, its controlled by the blitz.
I assume the wastegate has a 10psi spring, but as i said it was running 17 psi comfortably.
Limp mode really??
Dont get me wrong I'm not arguing ill check the ecu for codes, but wouldn't the car be alot less drivable? Iv been driving it too work for the last 3 weeks and its been like this for 5 weeks now.
headshotnz
Postby iOnic » Sat May 26, 2012 9:45 pm
Limp mode reduces boost via t-vsv. Car is still drivable, just has bugger all timing and bugger all boost
Postby headshotnz » Sat May 26, 2012 11:01 pm
iOnic wrote:Limp mode reduces boost via t-vsv. Car is still drivable, just has bugger all timing and bugger all boost
Rightio cheers for that.
So best idea would be too put it in diag mode and see what codes it pulls?
Its probably the AFM lol.. lucky I have a spare.
headshotnz
Postby headshotnz » Sat May 26, 2012 11:33 pm
ill be checking the limp mode.
Does any one know how to tell if the wastegate is stuck open, or what the symtoms would be.
How the hell am i going to be able too find a wastegate for a ct20b. omg.
headshotnz
Postby iOnic » Sun May 27, 2012 10:39 am
It's probably knock. Those Blitz access ECU's aren't tuned for NZ fuel. Symptom of waste gate stuck completely open is no boost. Partially open is very little boost and massive lag.
Postby headshotnz » Sun May 27, 2012 11:46 am
Thanks for that, pulled codes
4-3
3-1
2-1
2-4
Ill be looking those up now
headshotnz
Postby Grrrrrrr! » Sun May 27, 2012 11:57 am
43 starter motor signal
31 AFM signal
21 O2 sensor
24 Intake air temp
Sounds like your AFM is bung or not plugged in.
Grrrrrrr!
Postby headshotnz » Sun May 27, 2012 12:17 pm
Grrrrrrr! wrote:43 starter motor signal
31 AFM signal
21 O2 sensor
24 Intake air temp
Thanks for that.
Ill swap over the AFM now and see what happens. Its good having my project 2 sitting there in bits that i can steal parts from.. untill the day I wabt too get it working haha
headshotnz
Postby headshotnz » Sun May 27, 2012 12:40 pm
No change. Hmm. 02 sensor?
headshotnz
Postby Mr Ree » Sun May 27, 2012 1:00 pm
Is the vacuum line that goes to the WG actuator still intact?
wak thud gush!
Mr Ree
Postby headshotnz » Sun May 27, 2012 1:11 pm
I assume your talking about one of two thats at the top of the WG one pipe goes back too the turbo the other goes under the water neck.
But yeah mate they look in good condition.
headshotnz
Postby Dell'Orto » Sun May 27, 2012 1:13 pm
Its probably been knocking and pulling timing, Maybe reset the ECU and see how it goes.
Really, you need to get that boost under control, it wont last on 17psi
Postby Akane » Sun May 27, 2012 6:48 pm
Dell'Orto wrote:Really, you need to get that boost under control, it wont last on 17psi
but it pulls the mean as skidz :(
Postby headshotnz » Sun May 27, 2012 10:09 pm
Not with an open diff.
headshotnz
Postby Al » Mon May 28, 2012 11:49 am
<3 haters
Al
Postby headshotnz » Mon May 28, 2012 9:36 pm
I feel silly, the bolt at the top of the bov had fallen out. all is back too normal now :)
headshotnz
