bzrspeed wrote:Why do you need 300hp if it is a daily driven car? the WRC cars had 300hp.
Write down what you want it to be like, make a clear list of what your goal are.
I have been build race cars for over 12 years now and i know from experience daily driven race cars are a terrible idea.
When plan your build take into account, fuel lines, brake upgrade, diff upgrade, cooling upgrade otherwise waste money.
With 3s Toyota engine it is easy to get results, engine pretty well made from factory. But even WRC 3sge+t or 3sgte only last 800 mile before rebuild.
Never believe manufacture as they test engines with nothing attached. 260hp in Toyota world is maybe 220hp in real world. Renault are worst for this.
gt4toy wrote:I've just purchased an 1986 ST165 GT4 and I'm wanting to turn it into a track day car, as well as a daily driver.
300bhp is the goal, but I'm wondering if anyone else on here has done that, and what are the best parts to replace/modify/etc to get this.
I'm thinking of starting with swapping the engine out for a newer 3SGTE (ST215 I think) as they are already producing 260hp vs 185hp in mine and figure 75hp for a couple of grand is a good first step.
Rookie wrote:bzrspeed wrote:Why do you need 300hp if it is a daily driven car? the WRC cars had 300hp.
This is a retarded and completely irrelevant comment. For one, he isn't going to have a restrictor, so his peak power isn't going to be at 4500 rpm, and also his car isn't going to weigh the 1200 kg WRC weight limit.
Do beams motors go in celicas?
bzrspeed wrote:With 3s Toyota engine it is easy to get results, engine pretty well made from factory. But even WRC 3sge+t or 3sgte only last 800 mile before rebuild.
sergei wrote:Oh, and no matter what you do, the Hondas with half of power will still be running circles around you .
MR2SIK wrote:291hp gen3 on old skool linkplus, 95 octane. so woulda most likely hit 300 if 98 fuel was available. Also had a fault with the ignition that developed a miss after 6000rpm.
ct20b 16psi, light tickle with the valves & ports.
very doable, very responsive, very fun.
