Do not clip the jiggle valve from the thermostat
Postby gt4dude » Sun Jun 10, 2012 11:58 pm
Seen it mentioned before, But never really argued. To cut off the shitmetal from the thermostat bleed hole or not?
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby gt4dude » Mon Jun 11, 2012 12:08 am
I found the correct name it's called jiggle valve
200AWKW / 370NM
gt4dude
Postby matt dunn » Mon Jun 11, 2012 12:32 am
No it's there for a reason.
If you fit the thermostat properly it will do what it is meant to.
Postby ch4ng » Mon Jun 11, 2012 9:26 am
I've always removed it, it aids bleeding the cooling system quicker. Some thermostats don't come with them. (oem or aftermarket)
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
MX5 turbo - El Tigre
87 Alto - The Tragic 3cyl powah
AE111 BZ-G Death Race 15.09
No Limits Onsite Paint Repairs. Cut and polishing, stone chip and scratch repairs. 021-177-8539 Mention Toyspeed.
ch4ng
Postby QikStarlie » Mon Jun 11, 2012 5:53 pm
as matt says. there for a purpose. leave it. without it engine will take longer to warm up. an can run too cold. (overrun down a long hill you will find it will drop)
QikStarlie
Postby ch4ng » Mon Jun 11, 2012 8:01 pm
QikStarlie wrote:...without it engine will take longer to warm up...
We are talking about a 3mm hole here. Can't say I've experienced any problems (warm up or running cold)
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
ch4ng
Postby rollaholic » Mon Jun 11, 2012 8:18 pm
if you think you are smarter than the engineers who built your car, then by all means remove it.
Postby AE82 FXGT » Mon Jun 11, 2012 9:57 pm
rollaholic wrote:if you think you are smarter than the engineers who built your car, then by all means remove it.
Seems most people think they are.
Sure there are areas of compromise for mass production, but there are many things engineers have put serious work into.
AE82 FXGT
Postby matt dunn » Mon Jun 11, 2012 10:58 pm
yeah man remove it,
think of the weight you'll save,
it will shave 1/2 a yoctosecond off your 1/4 mile time,
(haha google that)
Postby Quint » Tue Jun 12, 2012 9:22 am
I've had thermostats with jiggle valves, thermostats without jiggle valves, i've replaced ones without jiggles with jiggles and ones with jiggles for ones without jiggles, i've cut jiggles off, i've left jiggles on, i've been told to leave the jiggle alone, i've been told to take the jiggle off.
I've juggled all of these jiggly things.
and the conclusion?
it doesn't $&#$% matter.
Quint
Postby Alex B » Tue Jun 12, 2012 11:54 am
HAHAAAA jiggly parts.
Postby gt4dude » Tue Jun 12, 2012 6:06 pm
u guys are right, swapped the jiggly clipped t-stat for a new stock one, car warms up much much quicker. case closed, dont do it. if theres a need for more coolant flow and more bleeding, the problem lays elsewhere.
200AWKW / 370NM
gt4dude
Postby Lloyd » Tue Jun 12, 2012 7:04 pm
Alex B wrote:HAHAAAA jiggly parts.
Postby QikStarlie » Tue Jun 12, 2012 7:26 pm
gt4dude wrote:u guys are right, swapped the jiggly clipped t-stat for a new stock one, car warms up much much quicker. case closed, dont do it. if theres a need for more coolant flow and more bleeding, the problem lays elsewhere.
boom
QikStarlie
Postby 3T-Rona » Wed Jun 13, 2012 11:23 am
matt dunn wrote:yeah man remove it,
(haha google that)
1 ys: time taken for a quark to emit a gluon.
think of the gluon's u can emit with the time saved
PM me for anything autoelectrical, Info or jobs etc....
3T-Rona
Postby xsspeed » Wed Jun 13, 2012 1:47 pm
(haha google that)
half of one?
