changed the coil to an aftermarket one and now it wont start
Postby tim_blair » Sun Jun 24, 2012 7:08 pm
i changed my coil to an aftermarket one and it didnt work so i changed it back to the factory one but now it doesnt work
it turns over but no spark
its a BT 4age with link storm ECU
i looked at all the fuses i could find but they are all ok is there any less obvious fuses that i should check?
what could be the cause?
does anyone know where there is a wiring schematic that i can look at?
girl: can I trust you?
me: you can trust anything :D
tim_blair
Postby Grrrrrrr! » Sun Jun 24, 2012 7:12 pm
What sort of coil did you put onto it? WAS it a MSD (or other CDI type) coil?
Grrrrrrr!
Postby tim_blair » Sun Jun 24, 2012 7:18 pm
tim_blair
Postby Grrrrrrr! » Sun Jun 24, 2012 7:32 pm
just noticed you are using a link....what igniters are you using?
Grrrrrrr!
Postby tim_blair » Sun Jun 24, 2012 7:37 pm
factory
tim_blair
Postby QikStarlie » Sun Jun 24, 2012 8:02 pm
looks like a cdi coil. probably cooked your ignitor. hope it hasnt damaged the link.
did we not advise you against doing this in another thread?
QikStarlie
Postby tim_blair » Sun Jun 24, 2012 8:05 pm
yes you did advise me against doing this with a different coil so i chose one that was "aparently" more compatable but obviously it wasnt
tim_blair
Postby QikStarlie » Sun Jun 24, 2012 8:11 pm
ah yeh. first thing i'd try is another ignitor with the stock coil.
will most likely be the problem
QikStarlie
Postby tim_blair » Sun Jun 24, 2012 8:14 pm
are they common amongst toyotas? or will i need to get a BT specific one?
tim_blair
Postby QikStarlie » Sun Jun 24, 2012 8:22 pm
others will work. some have different plugs though. on the link it will only be using 3 of the teminals/wires
ive used quite a few toyota ones on links, but cant help with what will interchange with a blacktop one though sorry
another thing.. did you ground the igintor case when you changed the coil? as they ground through the case
QikStarlie
Postby tim_blair » Sun Jun 24, 2012 8:27 pm
not at first as the instructions didnt say to do so, then when it didnt work i earthed it, but still no luck
tim_blair
Postby tim_blair » Sun Jun 24, 2012 8:31 pm
actually no sorry i thort you said coil case but i moved the igniter so the coil wires would reach and never earthed it so maybe that is the problem ill go have a look
tim_blair
Postby tim_blair » Sun Jun 24, 2012 8:38 pm
YOU MOTHER F@CKING LEGEND IT WORKED!!!!!!!!!!!
so you just saved my car whats your account number?
tim_blair
Postby QikStarlie » Sun Jun 24, 2012 8:45 pm
haha all good. Don't worry earthing the igntor case has tricked many many people!
QikStarlie
Postby tim_blair » Sun Jun 24, 2012 8:48 pm
man i cant believe that! who would have guessed that with all those wires coming out of it is still earths through the case,
so do you think i should try hooking up my new coil now?
tim_blair
Postby allencr » Sun Jun 24, 2012 9:12 pm
tim_blair wrote:so do you think i should try hooking up my new coil now?
Go for it & please write about the sparks appearance length & difference from the old one.
allencr
Postby QikStarlie » Sun Jun 24, 2012 9:18 pm
yeh nar
"Ultra Low 0.32 primary resistance"
cdi coil is no good for your setup. there is no need to upgrade the factory coil unless you have a misfire. which you wont on a na setup. nothing to gain, not broken, dont fix it
QikStarlie
Postby tim_blair » Sun Jun 24, 2012 9:36 pm
if i did it what could it possibly damage?
tim_blair
Postby QikStarlie » Mon Jun 25, 2012 8:26 pm
ignitor and possibly the coil.
you need a coil that works with inductive system, if youre set on changing the coil
QikStarlie
Postby tim_blair » Wed Jun 27, 2012 9:12 pm
what is the reason you think that it will damage my ignitor/ coil?
is it bacause of the low primary resistance?
if so could i put a resistor in series before the coil to reduce the current draw?
can you please explain what you mean by a coil that will work with an inductive system?
tim_blair
