4AGE water pipe - whats this for?
Postby gmacrae » Sun Jul 01, 2012 10:45 pm
Can anyone tell the the purpose of the small steel water hose that runs from the thermo housing under the intake manifold to the radiator pipe housin on the front of the motor. What's it for exactly? Cold thermo bypass? Is it necessary? I'm not running any heater or throttle coolant pipes.
gmacrae
Re: 4AGE water pipe - whats this for?
Postby allencr » Mon Jul 02, 2012 8:34 am
gmacrae wrote: Is it necessary?
Street engine, thermostat? Yes it's necessary to circulate coolant.
allencr
Postby gmacrae » Mon Jul 02, 2012 9:09 am
cheers, was beginning to think it must be :D
gmacrae
Postby Allister S » Wed Jul 04, 2012 2:05 pm
Hey,
Just wondering if this is a 16 Valve 4A motor with the starter motor on the intake side of the gearbox?
I'm putting in a C160 with a Bigport (AE82) and want to try and fit a starter on the intake side. Looks like it fits on your motor?
Thanks, Al
NZ AE82 GL Liftback Tarmac Rally spec
NZ AE82 GT Liftback x 2
R32 Skyline GTS-t Type M Coupe
'07 Subaru Legacy GTB
'03 Runx 2ZZ-GE 6spd
Allister S
Postby gmacrae » Wed Jul 04, 2012 2:41 pm
Allister S wrote:Hey,
Thanks, Al
Hey, yep it's a aw11 mr2 - 4a-gze. The starter is on the intake side factory. I put a c160 with silvertop in my ae92 with the starter on the intake side. I cant remember if the c160 had both starter humps or just intake side - it will fit there though, the engine blocks dont care where the starter sits, you just gotta have a bell housing to accommodate it (which you should have with the c160).
gmacrae
Postby 1I1 » Wed Jul 04, 2012 2:58 pm
C160 has humps on both sides
TRD Clicky >>Here
1I1
Postby Mr Revhead » Thu Jul 05, 2012 11:39 pm
my humps, my humps my.... oh... sorry....
