BZG Wagon wrote:Hopefully getting a Terrano in a few weeks and I'd like to take it off roading, but I don't have much (...any ) experience.
The ute has 3 settings (4-high / 4-low / 2wd). My thoughts for each gear are:
* 4wd - High (Gravel / Sand / Mud / Water)
* 4wd - Low (Rock climbing / steep bumpy dry hills etc. Basically I'll never use it)
* 2wd (Tarmac - presume this is RWD)
Is this right? Should I use 4wd-high when driving on sand and gravel at speed (say 50 - 60kph)? Or am I better flicking into 2wd for speed or long distances and switch to 4wd on difficult stretches?
Also does this sound right:
* I hear letting the ute largely do its own thing is often the best way to get over difficult surfaces when you're a novice.
* My Dad taught me to cross streams at an angle following the flow of water, so the cars momentum is working with the stream.
* If you can't move forward, just keep reversing pack and pushing forward to carve out a bit of a track for the wheels (in essence inch forward).
* Lower tyre pressure before getting into really loose terrain (mud, soft sand etc).
* A friend recommended I cote underneath the car with some sort of paint (he couldn't remember the name) to stop corrosion. Any recommendations?
* What are some basic cheap items I should carry to get out of trouble (rope, shovel & air compressor come to mind).
Any other tips?
I'm thinking of exploring out around Muriwai & South Head to being with, with a few tracks connecting the forrest and beach I've stumbled on over the years.
It'll be a 2.7L Diesel Automatic.
Elmo wrote:(I dont do extreme stuff)
rollaholic wrote:i sorta been thinking about this too lately.
anyone got a ballpark on what a basic rig might cost for a total newb?
BZG Wagon wrote:Elmo wrote:(I dont do extreme stuff)
BZG Wagon wrote: What are some basic cheap items I should carry to get out of trouble (rope, shovel & air compressor come to mind).
~SlideWays~ wrote:DO NOT USE A SNATCH STRAP ON THE TOWBALL! They are not designed to take that kind of shock, the ball will snap off with the force of 2500kg's and go through someones face.
Quint wrote:~SlideWays~ wrote:DO NOT USE A SNATCH STRAP ON THE TOWBALL! They are not designed to take that kind of shock, the ball will snap off with the force of 2500kg's and go through someones face.
Seen someone rip off their bullbars doing something similiar, wasted the arse end of the tow vehcile.
Users browsing this forum: No registered users and 56 guests
