1I1 wrote:I enquired about getting an exhaust cert a couple of years ago but didn't bother going through with it. From memory was around $150
BZG|Bling wrote:If the spacers are specified on cert plate they are legal. if they aren't they aren't legal, pretty simple.
cat007 wrote:1I1 wrote:I enquired about getting an exhaust cert a couple of years ago but didn't bother going through with it. From memory was around $150
Sweet - well I might as well do that then - if it's the same price as the ticket then it would seem a bit silly to not get it done. As long as it's under the 90db limit haha
Has anyone got a db meter I could borrow to see if I'll pass before forking out $150?
Quint wrote:I've got a db meter, but doubt you want to go the distance.the reason he pulled me over was because he noticed I was using a spacer for my wheels (20mm spacer).
what a hawk eyed mofo.
cat007 wrote:strx7 why do you ask about the cage and motorsport card?
strx7 wrote:cat007 wrote:strx7 why do you ask about the cage and motorsport card?
cause if you have an authority card the exhaust noise "similar to factory" law goes out the window
