strx7 wrote:www.coolingmist.com
i'm currently running a pair of 2GPH nozzles on my cruiser but will soon be adding a 5GPH nozzle to it aswell
strx7 wrote:yes it is the US, the only pumps i can find that are similar in NZ are close to $500 each.
does the pump you are using have a built in regulator so you can set it to say 200psi and it will prime then only turn on when the pressure drops below 200psi?
is it also safe to use with methanol or other alcohols?
can it also run dry without causing any issues?
the cooling mist pump can flow over 15GPH @ 250psi
I'm triggering it off a pressure switch
Meths & water is like NOS on a deisel
