[/quote]cedwards wrote:sorry hijack,
always wondered on the limitations of modding a diesel
How much extra boost and non-compressible liquid can you throw at an engine that relies on compression (with a little help from residual heat) before it starts detonating?
bzrspeed wrote:Remember also it is not water that is going into the engine. It is water vapor! That is a big difference.
sergei wrote:bzrspeed wrote:Remember also it is not water that is going into the engine. It is water vapor! That is a big difference.
Nope, the water mist goes into engine (little droplets of liquid water), not water vapour. Otherwise water injection would be pointless. The energy required to change state (from liquid to gas) of the water is what making water injection work.
bzrspeed wrote:I am sorry but I disagree.
I am not doing the setup for power, I am using the water injection to minimise the onset of detonation or even totally eliminate it. The twin cam engine has a few well know detonation issues and running of the high compression pistons and the fuel (96) which I will be using i am making it a safe guard.
The Twincam uses a 11.5 compression ratio engine and from what Guy Croft was emailed me and I trust his experience, the meth/water injection has been proven to be a great addition to high compression Twincam powered cars. Due to the high compression, high revving engine the benefits are the cooling of the intake charge and increase of octane
I do not think it is a big power adder but a good insurance for keeping the twincam alive above the 7250rpm level. Plus its only going to work above 3/4 throttle.
STRx-7 what ratio of meth/water do you use? i was thinking 25% to 35%. i know the maximum is 50% but dont want to go close to that.
sergei wrote:bzrspeed wrote:I am sorry but I disagree.
Pushing out 180Hp out of 2L twincam is nothing dramatic that requires water injection. It is possible to have 180Hp with 2L and 91 Octane without detonation issues.
