phoenix wrote:What weight oil are you running?
DXROLLA wrote:phoenix wrote:What weight oil are you running?
What oil would you recommend?
TRD_ZERO wrote:Could be front seals on the turbo or like mentioned earlier the breather lines going to the intake as you said oil level was high. Check your intake for oil and while it's off check compressor wheel for oil and so on.
