jacobrjett wrote:yea thats wat im thinking i mean once its there its there, so im not expecting it to suddenly become better - but i am adamant that you can barely hear it when its warmed up. well, lets say the knock is coming and going.
dont get me wrong I understand when it comes to rod knock, its $&#$% and its not going to fix itself. but it definately seems to come and go.
im wondering if the builder used the wrong size bearings or something, and the knock is coming and going due to it sometimes getting oil pressure in the bearings and sometimes not...
either that or the oil pump should have been replaced.
MilfHunter wrote:If the sizes were wrong it would have knocked from the 1st start. Once a B/E bearing goes it will only get worse till the rod lets go.
Sounds like you have a failing oil pump or a sticky relief valve to me
Can someone explain how you can keep driving with an oil light on? Sure momentary on a track under braking etc is understandable.
4agtepwr wrote:Put an oil pressure gauge on it and have a look at oil pressure, the vvt pulleys make more of a rattle than a knock. Also you can do an oil change and cut the old filter open, if you can see gold or metallic specs in there you have problems. That crank measured mint, what rods did you use and had they been resized?, When you first cranked it did you have the plugs out till the oil light went out? I went and pressure lubed a 4agte I built for a guys race car today, It would make 70 psi on the starter with the plugs out, As a new 4age should with the right bearing clearances and a oil pump that is in good condition.
jacobrjett wrote:Tomorrow ill pull the sump, check the bearings, and check out the oil pump.
allencr wrote:Bearing noise NEVER goes away except for the half-dozen knocks you'll get on an engine with loose bearings that's very dry/drained, and disappears in a second or three with oil pressure.
