Welling Ferry
Welling Ferry
Postby diss7 » Fri Aug 17, 2012 9:56 am
Any comments about which ferry is best for modified cars?
Last time I went on the interislander (admititly is was about 8 years ago) I recall a gap/drop that was viscous and I ended up cracking the front kit.
Thanks.
diss7
Postby 1I1 » Fri Aug 17, 2012 10:12 am
Bluebridge seemed good - though the front lip on my Corolla isn't that low. But IMO the angles didn't look too bad on their ramps.
Worst part was driving up into the parking area (and going down when leaving). Was a tad shakey with hard suspension due to the surface they use to stop tyres slipping :lol:
TRD Clicky >>Here
1I1
Postby GDII » Fri Aug 17, 2012 11:33 am
Been on blue bridge but they don't appear to have that ship anymore. Was fine but very bumpy as 1I1 said. I will be going on Interislander and then blue bridge over Christmas but will likely have put my stock springs back in by then.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby Bling » Fri Aug 17, 2012 2:48 pm
Yeah Ferry terminals are not built to suit our cars. I had to go on a stupid angle to not hit on the Interislander. Much to everyone elses amusement :oops: then as above, the ramps vibrate any loose teeth out.
Postby diss7 » Fri Aug 17, 2012 4:34 pm
Well I've booked to go on the interislander tomorrow night, so we'll see how I go.
diss7
Postby DRFTIN » Fri Aug 17, 2012 5:31 pm
depends on the individual boat and who the guy working at the ramp is. couple of times i've been put in the lower deck with trucks when they dont think i'll make it up the ramp, also get to leave first from there ;)
the first ramp isnt so bad as you can take at a big angle if needed
DRFTIN
Postby Jdawg » Fri Aug 17, 2012 5:37 pm
Arrive early and chat to the office and ask to be put on the lower deck. If they are not full with trucks they won't mind helping you out. That is both Ferry companies.
I also got sick under a table on the Bluebridge ferry last time.
Jdawg
Postby Al » Fri Aug 17, 2012 7:39 pm
Had no problem with the MR2. Mind you, it isn't scraping low.
Al
Postby MR2SIK » Fri Aug 17, 2012 10:29 pm
at Megameet in Auckland a few years ago, the guy working the ramps on both journeys was good with letting me take the ramp at an angle, slowed down cars behind me to give me a chance. That was on Interislander.
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Postby fangsport » Sat Aug 18, 2012 12:07 am
it's far easier for the loading staff to let you come onboard slowly and at angle, than to shag around helping you pick up bits of plastic.
fangsport
Postby diss7 » Sat Aug 18, 2012 7:41 am
Thanks for the tips.
I don't think this car is crazy low, but we'll soon see
diss7
Postby KwS » Sat Aug 18, 2012 5:52 pm
bluebridge was fine when i used them last, went on their older, bigger ship (whatever its called). But as said above, those grip bumps on it are brutal
KwS
Postby matt dunn » Sat Aug 18, 2012 9:33 pm
To be honest it depends on the tide,
as the wharf is at a fixed height but the boat isn't,
so the angle really depends on that.
We went on the same boat both ways when we raced at taupo, and the ramp was different angles both ways.
Postby diss7 » Sun Aug 19, 2012 7:22 pm
Turns out I was worried over nothing, easy on easy off.
diss7
