st215 caldina gtt boost problem
Postby fivebob » Mon Aug 27, 2012 3:26 pm
Al wrote:The real reason it will boost lower in the first two gears is there isn't enough load to produce anymore.
Not quite correct. With a good electronic boost controller you can get 18psi in all gears. Stock boost control shouldn't have that much of an effect on that. Might also be that the boost gauge is to heavily damped to register properly.
Postby fivebob » Mon Aug 27, 2012 3:36 pm
BS there's no gear detection so the ECU can't regulate boost based on gears.
Diff Speed/Engine RPM = Gear Ratio
Maybe in theory, but there's no evidence to suggest that the ST215 ECU does that, in fact there's evidence that it doesn't because when you change the speed signal by using a divider circuit nothing else changes apart from the speed cut.
Postby MRDOCA » Mon Aug 27, 2012 4:36 pm
thanks guys for your input. dunno why its only 7-8 psi in first and second though, could be due to the boost gauge reading wrong i suppose
1997 Caldina GTT, Manual, TEIN adjustable suspension, turbosmart bov, 3" exhaust ***Work in progress***
MRDOCA
Postby MRDOCA » Tue Aug 28, 2012 2:23 pm
Another question. Which pins do i loop on this diagnostics obd2 looking plug?
MRDOCA
Postby fivebob » Tue Aug 28, 2012 3:13 pm
MRDOCA wrote:Another question. Which pins do i loop on this diagnostics obd2 looking plug?
Jumper pins (13) "TC" & (4) "CG"
Sorry don't have a picture of the port but I'm sure you can find one easy enough.
Postby MRDOCA » Tue Aug 28, 2012 4:07 pm
MRDOCA
Postby fivebob » Tue Aug 28, 2012 4:20 pm
Yes those look like the right ones.
Postby MRDOCA » Tue Aug 28, 2012 4:26 pm
ok so did it...
excuse the super noob-ness of this lol
the engine check and abs light flashed constantly.
the airbag light flashed 8 then stopped then 4.
so if its error 84?? what is that?
MRDOCA
Postby fivebob » Tue Aug 28, 2012 4:32 pm
MRDOCA wrote:ok so did it...
84 Open In Curtain Shield Air Bag RH Airbag or explosive module Circuit
Postby MRDOCA » Tue Aug 28, 2012 4:33 pm
but thats not why its pinking its ring though aye?
would plugging this into a scan machine at my brothers work produce a different result?
MRDOCA
Postby fivebob » Tue Aug 28, 2012 5:06 pm
MRDOCA wrote:but thats not why its pinking its ring though aye?
No, just means your airbag won't work.
Probably not unless it's portable and one of the few that can actually get data from a ST215. Then you could take out for a drive and log the ignition timing. AFAIK there are no codes that are not displayed by bridging the terminals.
Postby MRDOCA » Tue Aug 28, 2012 5:09 pm
that sucks. any ideas why its pinking? it does it all the time now.
MRDOCA
Postby snwtoy » Tue Aug 28, 2012 5:35 pm
What gas are you running in it, and have you checked the fuel filter and pickup (based on my recent experience with the car cutting out).
snwtoy
Postby MRDOCA » Tue Aug 28, 2012 5:39 pm
atm im running 95. but ive run 98 for ages and made no difference. i know i should run 98 fuel but with petrol prices atm no job and kids to feed its a bit hard. fuel filter could be a good idea actually. i'll check it out or just replace it. i'll lift up the rear seat tomorrow and check the pickup, what would i be looking for?
MRDOCA
Postby diss7 » Tue Aug 28, 2012 6:22 pm
MRDOCA wrote:atm im running 95. but ive run 98 for ages and made no difference. i know i should run 98 fuel but with petrol prices atm no job and kids to feed its a bit hard. fuel filter could be a good idea actually. i'll check it out or just replace it. i'll lift up the rear seat tomorrow and check the pickup, what would i be looking for?
A job.
diss7
Postby snwtoy » Tue Aug 28, 2012 6:28 pm
^^haha,
Just gunk in the pickup.
When my filter was replaced, we determined that the fuel was turning black after it passed the filter, there was that much crap in it.
With regard to the fuel, Caldina is super-sensitive to the octane (due to the high compression i think?) - remembering it was designed for 100. fivebob will be able to tell you more, but yeah, I'd switch back to 98 if you want it to last. There was someone who ran a small amount of 91 as the local gasser ran out of anything better. A short time later the engine died.
snwtoy
Postby MRDOCA » Tue Aug 28, 2012 7:27 pm
Sweet. Thanks, ill check it out.
MRDOCA
Postby Al » Tue Aug 28, 2012 7:40 pm
Yes running 95 is so much cheaper at about $2 per tank fill.
Al
Postby MRDOCA » Tue Aug 28, 2012 8:01 pm
Just found out my brothers work has one of those mobile scanners so fingers crossed we can sort it
MRDOCA
Postby sergei » Wed Aug 29, 2012 10:12 am
Al wrote:Yes running 95 is so much cheaper at about $2 per tank fill.
and will cost you the same if not more once calculate cost per km.
