4agze Fuel rail leaking
Postby mlewis » Fri Aug 31, 2012 12:35 am
Went to crank over my 4agze turbo conversion tonight and found fuel leaking/spraying out from what I think is the cold start injector. Its coming from the bolt on the fuel rail itself found just before the end of the rail nearest to cam belt end.
Found the bolt tight at both ends of the hose ( connects from fuel rail to intake manifold)
Any other ideas what could be causing this?
mlewis
Postby loudstealthGT-Four » Fri Aug 31, 2012 1:42 am
have you got the washers on the bolts?
like this pic (pic is actually of a 3S but same idea)
loudstealthGT-Four
Postby mlewis » Fri Aug 31, 2012 3:19 pm
will check tonight, have a feeling from what my tutors have said today to check for the copper washers
mlewis
Postby Heylin » Fri Aug 31, 2012 4:22 pm
Pays to replace them and not reuse the old washers, they are crush washers, use once throw away.
Fuel is risky stuff if it sprays onto hot motor :)
Heylin
Heylin
Postby AE82 FXGT » Fri Aug 31, 2012 7:03 pm
Heylin wrote:Pays to replace them and not reuse the old washers, they are crush washers, use once throw away.
Yes this.
For the price of copper washers, it's a bit silly to reuse them.
If they are there, replace them.
AE82 FXGT
Postby mlewis » Fri Aug 31, 2012 10:14 pm
turns out i was missing a washer exactly where i thought so brought a pack for 6bux and replaced both, now there is a another leak which is coming from near the middle of the fuel rail. So if i have no work on sunday i will be ripping out the fuel rail and redoing
mlewis
Postby Heylin » Fri Aug 31, 2012 11:47 pm
mlewis wrote:turns out i was missing a washer exactly where i thought so brought a pack for 6bux and replaced both, now there is a another leak which is coming from near the middle of the fuel rail. So if i have no work on sunday i will be ripping out the fuel rail and redoing
Middle, injector O ring perhaps ?
Heylin
Heylin
Postby mlewis » Fri Aug 31, 2012 11:53 pm
I'm thinking it has to be the orings or something similar, Its a big port manifold and the leaks is from the middle split in the intake runners
mlewis
Postby mlewis » Sat Sep 01, 2012 12:45 pm
Whats the best thing to clean off the fuel with, my exhaust pipe currently stops under the sump inline with where the fuel was dripping so need to clean the excess off my firewall before starting it up to check the earthing issues
mlewis
Postby mlewis » Sat Sep 01, 2012 11:02 pm
here are some photos of the top of my injectors, leads me to believe the o rings are stuffed. Also if i put bigger injectors in do i need to change my FPR or can i just put in some 440cc or 510ccs and be away laughing?
mlewis
Postby Crucible » Mon Sep 03, 2012 11:35 pm
Stock reg will be fine. Just use water to rinse off petrol or degreaser if you have some.
Crucible
Real Life Mechanic
Postby mlewis » Mon Sep 03, 2012 11:50 pm
so can go as big as 510-550cc running factory ecu and have no problems and not run too rich?
mlewis
Postby levinguy » Mon Sep 03, 2012 11:58 pm
mlewis wrote:so can go as big as 510-550cc running factory ecu and have no problems and not run too rich?
no, it will run richer unless you change the ecu or trick it somehow
levinguy
Postby gt4dude » Tue Sep 04, 2012 12:10 am
3s has a cold start injector??? ive never seen 1 ;S
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby Dell'Orto » Tue Sep 04, 2012 12:16 am
Don't know if Gen 3's do, but certainly Gen 2 does
