Hydraulic handbrake remote reservoir
Postby neo » Wed Sep 12, 2012 8:58 pm
Hi all
I'm working currently to install a second pair of rear calipers on the back of the racecar as I intend to re-install the hydraulic handbrake to actuate the second set of calipers (the events in Wellington almost always involve a hairpin).
The handbrake I plan to put in has a 3/4 bore with two threaded ports, as I dont plan this to be inline with the normal brake line I need to give this a dedicated reservoir.
Does anyone know where I can get remote master cylinder reservoir from?
Currently my options all include throwing away the master cylinder I already have and then:
* install a Wilwood one that comes with a remote reservoir kit
* install a trailer master cylinder (trojan etc) with direct attached reservoir
**I haven't called the likes of BNT or ABC yet, but spent afew hours on google**
neo
Postby KwS » Wed Sep 12, 2012 9:20 pm
What about something like the remote res used on most 90's hondas? They have remote clutch reservoirs. Used on Civic, Integras, preludes.
Otherwise some motorbikes used remote brake reservoirs.
KwS
Postby YeMs » Wed Sep 12, 2012 9:36 pm
lol, or grab a trailer master with built in resevoir ;)
Your local Hybrid Elite tech
YeMs
Postby KE20 » Wed Sep 12, 2012 9:52 pm
get one from a van from a wrecker.
the resivor on a master is held on by a massive hollow bolt from memory, you just unscrew it and lift off the rsovir, all vans ive seen have a remote resivor, you just get the banjo bolt from that master and screw it in,
easy as.
Garage Dori
current cars; , 2JZGE-YN57R Hilux double cab, Ipsum Sport, 1948 Ford F1
prevous cars; JZX81 X2, LX80, , 1JZGTE-JZX81, KE20-3SGTE, KE35-4AGE, KE35-3A, KE30, KE36, TE71, AE85, AE86, KE70 X4, KE20, 1JZGE-VVTI-JZX100, GX90, CT170, VW(beetle) x 5,(Kombi) x 2, mazdas x heaps, +more
KE20
Postby Boost_4_Life » Thu Sep 13, 2012 10:48 am
how come you arent going in line with the normal brake line?
'83 KP starlet rally car, 20v powa!
The rally beast
The rally beast again!
Boost_4_Life
Re: Hydraulic handbrake remote reservoir
Postby Distrb » Thu Sep 13, 2012 11:12 am
neo wrote:* install a trailer master cylinder (trojan etc) with direct attached reservoir
this ^
i have a spare trailer one if you want it for mocking up purposes etc..
Distrb
Regular Poster
Postby neo » Thu Sep 13, 2012 1:05 pm
Boost_4_Life wrote:how come you arent going in line with the normal brake line?
Cause I did this in the past and found it very discocerting when braking.. .. my old H/B now belongs to Distrb :)
neo
Postby Boost_4_Life » Thu Sep 13, 2012 2:21 pm
thats a little odd, shouldn't really have any effect on normal braking at all? Unless you arent running seperate front and rear circuits with seperate master cylinders?
The rally beast
Boost_4_Life
Postby Distrb » Thu Sep 13, 2012 3:14 pm
Boost_4_Life wrote:thats a little odd, shouldn't really have any effect on normal braking at all? Unless you arent running seperate front and rear circuits with seperate master cylinders?
i had it on both stock master cylinder and split master cylinder and it was fine. though i havent found myself in the situation where i need to be using the service brake and the hand brake at the same time.
Distrb
Regular Poster
Postby Boost_4_Life » Thu Sep 13, 2012 5:26 pm
Distrb wrote: though i havent found myself in the situation where i need to be using the service brake and the hand brake at the same time.
Yea same here I guess. with adjustable bias it opens up a whole new world :lol:
The rally beast
Boost_4_Life
Postby slighty_looney » Fri Sep 14, 2012 9:07 am
I'm currently doing the same setup on my rx7. You'll need a 3/4 clutch master or like I did and as said above use a trailer one. As they are the right size and only 40$
FC3S
Robinson Steel Fabrications
Current Ride: 88 rx7
Project: viewtopic.php?t=88412
Discussion: viewtopic.php?t=88413
slighty_looney
