Just to be real quick here
Length and Width and Grade etc... Please let me know if anyone can help!
Car:
Toyota Celica 1990 GT4 Widebody ST185
gt4dude wrote:hit up Mark @ Toyota NZ for coolant hoses, eg, hose from hell, oil cooler hose, water bypass hose, heater hoses, throttle body coolant hose (i would bypass -- ID6mm coolant grade hose), the coolant hoses are cheap,
upper and lower radiator hoses, buy st205 silicone hose set from redline performance, should work, can compare measurements if u like
vacuum hoses - use 4 and 6mm silicone hose, buy yourself about 2m of 6 and 1m of 4
idler hose is ID13mm (AN -8 pushlock works)
turbo water feed & outlet is ID10mm (AN -6)
st205 turbo oil return hose is about ID19mm, not sure for st185
what else?
LEAKER wrote:Sounds like the pinging is causing the knock sensor to trigger. Hence the loss of power and wiered boost response.
LEAKER wrote:Yeah that's something I'm trying to work on. I haven't really had any experiance with pinging myself so I'm trying to think of causes hoping that someone else will chime in
How have you done the timing?
solitaire wrote:Hose and gravity is easiest.
Is it map sensored or afm? I had a 3sgte that was pinging, turned out to be a rooted afm.
