custom radiator
custom radiator
Postby touge_ae101 » Mon Oct 01, 2012 1:21 pm
I'm doing a 2zz conversion in my 101 with quad throttle's etc so i want to custom make a half-height radiator. dimensions will be somewhere in the vicinity of 500x350x70mm. idea is to have the trumpets sticking out the grill and radiator ducted separately to ensure i get nice cold air being forced into the throttles.
does anyone know of an outfit that will sell the core to me in a custom size like this? Or if its a decent enough price make the whole thing?
touge_ae101
Postby Distrb » Mon Oct 01, 2012 1:38 pm
my brother in law had a half height one made up to his dimensions by Heat Exchanger Services in CHCH that was reasonably priced.
http://www.heatexchangerservices.co.nz/performance.html
Distrb
Regular Poster
Postby Adoom » Mon Oct 01, 2012 1:57 pm
I've got one of these:
http://www.trademe.co.nz/motors/car-par ... 133158.htm
The dimensions are similar to what you want. I don't know about the pipes though...
Solved my cooling problems when giving it death at Manfeild. It's rock solid at 80degrees for "normal" driving, at the track it doesn't go above 85.
Adoom
Postby touge_ae101 » Mon Oct 01, 2012 4:15 pm
Cheers guys. chch outfit look like they are onto it. will see what the price difference is between just getting the core or getting a whole radiator made.
touge_ae101
Postby strx7 » Mon Oct 01, 2012 5:07 pm
that rad sounds about the size of alot of Townace/Liteace radiators
Postby touge_ae101 » Mon Oct 01, 2012 5:10 pm
Might have to look into that!
touge_ae101
Postby Dell'Orto » Mon Oct 01, 2012 6:47 pm
I got Real Deal Radiators in Henderson to do mine, was just shy of $700 but its $&#$% huge
Image[/img]
Postby Stu- » Tue Oct 02, 2012 12:20 pm
+1 for HeatExchangeServices
Project Thread
Stu-
Postby touge_ae101 » Tue Oct 02, 2012 12:33 pm
Had a quick look at dimensions last night with tape measure... getting trickier as i only have 200mm height to play with and 700mm width. Looking at angling the radiator now but all depends on how far back the block sits.
does anyone have any knowledge on efficiency of a radiator vertical flow vs horizontal flow?? I've been told it will effect efficiency quite a bit.
touge_ae101
Postby hsmidy » Tue Oct 02, 2012 5:51 pm
would depend on how good your ducting is
hsmidy
Postby Grrrrrrr! » Tue Oct 02, 2012 6:54 pm
touge_ae101 wrote:Had a quick look at dimensions last night with tape measure... getting trickier as i only have 200mm height to play with and 700mm width. Looking at angling the radiator now but all depends on how far back the block sits.
More short tubes will cool better than fewer long tubes since heat transfer is maximum where the temp difference is highest (ie, where the hot coolant enters the radiator) . But since you have SFA height to play with you probably dont want to lose more for inlet and outlet tanks...
Grrrrrrr!
Postby touge_ae101 » Tue Oct 02, 2012 7:44 pm
aha yes that makes sense. yeah thats pretty much what i was thinking. although i could make it only 20mm or so top/bottom.
touge_ae101
Postby nz_climber » Tue Oct 02, 2012 9:03 pm
I had A1 radiators in Christchurch do a custom radiator for my Lotus 7 replica, really happy with the end result as it fits perfectly in the space I had and water temp is stable on the track. Plus get all the fittings exactly where I need them, was well worth it.
Ended up getting a dual pass (horizontal flow) Core 400mm*390mm * 56mm
nz_climber
