snwtoy wrote: I unplugged the coils and turned it over till I had oil flowing through the turbo oil return.
Grrrrrrr! wrote:Before you go pulling lots of stuff off again, trying cranking for 20-30 secs with your foot flat to the floor. This puts many ECUs into a flood clearing mode. Make sure you have a fully charged battery.
Grrrrrrr! wrote:Not sure what Toyota ecus do it, but I believe most Ford, GM, and older bosch ecus, and several aftermarket ecus do it.
snwtoy wrote: I assume that having been sitting for more than 24 hours now it shouldn't be flooded any more?
matt dunn wrote:sorry but flooded is flooded, the fuel will still be there if your car has decent rings,
and spark plugs dont unfoul themselves while sitting.
presuming that is the problem.
MrOizo wrote:Maybe on one cylinder that had a valve left open after cranking.
If you havent changed the spark plugs in some time, this is a good time to do it. First start up after having it flooded and having changed the plugs is magical!
snwtoy wrote:At a physical level, if there's fuel sloshing around in the cylinders, what does 'flood clearing mode' actually do?
Users browsing this forum: Bing [Bot] and 28 guests
