wastegate advise
Postby gt4dude » Fri Oct 19, 2012 5:58 am
I have the 2012 MVR44, lol @ claims the outlet port is the same size as that on an F38
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby Mr Ree » Fri Oct 19, 2012 8:34 am
gt4dude wrote:I have the 2012 MVR44, lol @ claims the outlet port is the same size as that on an F38
Was Blake referring to that model?
If you could get some verniers and measure the ID of the outlet, just for interests sake, that would be good info for this thread.
wak thud gush!
Mr Ree
Postby Lith » Fri Oct 19, 2012 9:06 am
I got the impression that he measured it...
2007 Mazdaspeed Axela
Lith
Postby iOnic » Fri Oct 19, 2012 9:46 am
IMO if you're at the point where having an outlet port that is 1 or 2mm smaller than the valve is a problem, you're using the wrong sized wastegate altogether and going to a turbosmart isn't going to help you. Wastegates are such simple devices that it's hard for them to not work.
Also, the Hypergate and MVR share the same v-band kits so I'm not sure that their ports are vastly different.
Postby gt4dude » Sat Oct 20, 2012 12:25 am
i never measured it, i did note it was maybe 1mm smaller than the inlet if that. but nothing like a 38 no way
200AWKW / 370NM
gt4dude
Postby sergei » Sat Oct 20, 2012 8:48 am
there is a huge difference between valve being 38mm and outlet being 38mm. The 38mm Valve will flow a less than 38mm opening.
Users browsing this forum: Bing [Bot] and 17 guests
