4AGTE failure
4AGTE failure
Postby bluemaumau » Thu Jan 03, 2013 9:08 pm
hi guys
long time no see.
i havnt done any work on cars for a while but pulled the 4agte out of the garage just before xmas last year (im living in oz now, so thought i best take it for a thrash)
so i took it for a burn (around 30mins driving time - not giving it a belting, except on the odd straight)
went around a corner in boosting second into third - gate opened then i heard a popping type sound - close to a intercooler pipe blowing off.
then no drive and the engine stalled as i came to a stop on the side of the road.
the car turns over. it seems to be turning over quicker than before and to a different tune.
i realise its hard to diagnose based on provided info, but as i only have a week left in the country i thought id ask for peoples opinions on what to check..
ive checked the plugs - no oil (no oil/smoke in rear view)
checked I/C pipe work
checked wiring to fuel.
im going to dump the oil tomo and look for anything out of the norm. am i correct in assuming the faster turning over means the compression is buggered?
any ideas on what to attack would be appreciated
or if anyone wants to buy the thing let me know, going cheap :?
Postby RS13 » Thu Jan 03, 2013 9:11 pm
Probably stating the obvious, but you've checked the cambelt or timing?
RS13
Postby bluemaumau » Thu Jan 03, 2013 9:12 pm
not really mate, i havnt looked at a motor in 2 years now!
but yes i have checked that
Postby Nuty|Mike » Thu Jan 03, 2013 9:26 pm
might be a stupid idea ....does it have a dizzy?
A few years ago i had a bluetopd 4age wagon at the drags ,the rotor in the dizzy was old and it shattered on a run ,made the same noises you are talking about It even had the faster turning over you complain about......Just an idea may be waaayyy off tho.
05 Mazda Verisa .....for the Family
Nuty|Mike
Postby DVSMOTORSPORT » Thu Jan 03, 2013 9:28 pm
First stop is doing a compression test really
Hi Im Ben, Have a nice day :)
DVSMOTORSPORT
Postby Dell'Orto » Thu Jan 03, 2013 9:37 pm
^That. Does it start anymore?
Postby bluemaumau » Thu Jan 03, 2013 9:39 pm
will try that tomorrow also
thanks guys
Mike, it has a 4agze Crank Angle Sensor
Postby gepsk8 » Fri Jan 04, 2013 3:29 am
afm? blown intercooler pipe? lol shouldn't read post half asleep
definitely pull plugs check for compression.
O272754663
gepsk8
Postby rollaholic » Fri Jan 04, 2013 6:53 am
just to confirm you have turned the crankshaft, seen the belt move across cam sprockets, and all is well in timing land?
Postby sik_gt_starly » Fri Jan 04, 2013 12:53 pm
Snapped cambelt would be the first thing I would check, had the same happen to an old flatmate.
sik_gt_starly
Postby RS13 » Fri Jan 04, 2013 1:48 pm
bluemaumau wrote:im going to dump the oil tomo and look for anything out of the norm. am i correct in assuming the faster turning over means the compression is buggered?
Spinning over faster than normal would suggest that you've lost compression.. either the cambelt has broken or slipped a couple of teeth and bent valves. Are you absolutely sure that the belt is still timed right?
RS13
Postby d1 mule » Fri Jan 04, 2013 5:58 pm
^ non interference buddy.
d1 mule
Postby RS13 » Fri Jan 04, 2013 6:46 pm
d1 mule wrote:^ non interference buddy.
Oh yeah, my bad. Still.. typical causes of lost compression.
RS13
Postby bluemaumau » Sat Jan 05, 2013 2:16 pm
went to do the compression test today and realised the cam gears didnt rotate.
8O
ripped all the belts/pulleys and covers off to find the key from the crank lodged in the crank pulley [blew the section of pulley out]
crank sprocket seems to be fine as does the crank. [ except the sprocket is out of timing ]
so im hoping it is just a simple replace key and crank pulley
Postby RS13 » Sat Jan 05, 2013 5:55 pm
Wow yeah, that'd do it. Was the crank pulley bolt loose?
RS13
Postby DVSMOTORSPORT » Sat Jan 05, 2013 7:13 pm
Sweet not as bad as I was thinking. Hopefully an easy fix
DVSMOTORSPORT
Postby bluemaumau » Sat Jan 05, 2013 7:51 pm
RS13, im not sure as i attacked it with a impact wrench, however im thinking it was, with the ease it came off [makita cordless impact wrench]
so yeah need a 4age pulley asap, before i fly out of here!
Postby Stott69 » Sat Jan 05, 2013 8:50 pm
Hit up mark, had almost the same thing a while back.
Stott69
Postby matt dunn » Sun Jan 06, 2013 2:07 pm
yeah caused by the crank pulley not tight enough,
It happened to the first turbo motor I assembled myself years ago,
unfortunatly it bent 12 out of 20 valves on mine.
Postby bluemaumau » Sun Jan 06, 2013 3:48 pm
hopefully it didnt do anything like that,
no loud noises etc
fingers crossed
