The gauge cluster in the 86 has issues, just the tacho really. Have had a couple of people look at it and couldn't work out what the story is.
So looking at aftermarket tacho options. Ideally want something 0 - 9000rpm, with a shift light. Multiple shift lifts would be even better, think F1 etc.
Don't want anything overly gawdy or cheap. Just something clean and functional.
Cheers.
tacho options
diss7
http://www.ecliptech.com.au/index.php?option=com_content&view=article&id=59&Itemid=109
This thing looks the business
nz_climber
- Toyspeed Member
- Contact:
Tacho trigger signal...
spoonza6 wrote:red - ACC power
black - ground/earth
green - ???
Has to be the ignition/tacho signal. Won't do anything otherwise.
Check the instructions, or take a guess at what kind of signal the
tacho wants e.g. 5V, 12V, coil negative etc.
Cheers... jondee86
spec small port, twinscrew s/c and water/methanol injection
Watch this space >>> <<<
diss7 wrote:http://www.ecliptech.com.au/index.php?option=com_content&view=article&id=59&Itemid=109
x2
is impossible when things are busy. Changing by ear is easy enough,
but you can never be sure you haven't left yourself a few hundred rpm
short of your ideal shift point.
Cheers... jondee86
think bazda stocks them for a good price, few people on here have got them I think
Whats wrong with the stock tacho? Signal from the coils or ecu not driving it? You may need to change the restistor inside the tacho - relatively easy job
Project Thread
Project Thread
