BZG|Bling wrote:Mr Revhead wrote::o I needs me one of those!
Yeah that looks handy as, might have to make one!
They're good for a while, but they break the pins all the time
Dell'Orto wrote:BZG|Bling wrote:Mr Revhead wrote::o I needs me one of those!
RS13 wrote:Dell'Orto wrote:BZG|Bling wrote:Mr Revhead wrote::o I needs me one of those!
What are the pins made of?
Dell'Orto wrote:Did you tighten the crank pulley up to the correct torque afterwards? I would say about 35ft of rope would be about right
Dell'Orto wrote:Depending on the type of gun you used, it may not be done up tight enough. Worth checking at least, I doubt anything you would have done internally would cause a vibration at those kind of revs
I've remembered something else, before i resorted to the rope trick i had a old drive belt wrapped around the pulley to hold it still... wonder if i may have rooted the rubber in the balancer pulleyDell'Orto wrote:Ah well there you go...a lot of those cheap guns are only rated at 200ft/lbs max, and thats with decent air.
yeah, you've given me some good ideas/plans of action... cheers mate.Dell'Orto wrote:Only one way to find out
checked that last night, can definitely feel it on the guard. Im quietly hopefull i just need to tighten it to the right torque - glad i didnt decide to test drive it,Mr Revhead wrote:Gotta learn somehow!
Definitly check its tight. Can you feel the vibrations on the car itself? As in if you lean on the gaurd? Or is it only through the wheel?
solitaire wrote:sounds stupid i know but this stuff seems obvious once you say it but it doesn't occur to me - i think i need to stick to driving rather than fixing.
