FT86 vs BRZ
FT86 vs BRZ
Postby spoonza6 » Tue Jan 08, 2013 5:11 pm
is anyone else looking forward to how this is going to go down?
ive read rave reviews about the FT86 and that, but isnt an AWD version going to up the ante a bit more?
be even more dangerous if they fit a turbo and have a switch to disengage the front driveline for some rear wheel fun like the legacys did back in the days
pop the fuse and rwd skids on
spoonza6
Postby rollaholic » Tue Jan 08, 2013 5:13 pm
does it get more power?
seems like more weight / driveline is just going to make it slower in most situations
Postby spoonza6 » Tue Jan 08, 2013 5:25 pm
duh, its not AWD
rumours..........................
as you were
spoonza6
Postby diss7 » Tue Jan 08, 2013 5:49 pm
diss7
Postby rollaholic » Tue Jan 08, 2013 9:18 pm
spoonza6 wrote:duh, its not AWD
uh?
you were the one calling out AWD.
i dont get it :P
Postby FST4RD » Tue Jan 08, 2013 9:35 pm
From what I have read, they're identical apart from the badges.
The Subarus lowest model will be the same as the GT86, and STI is going to do a version as well, similar to the TRD model.
So Subaru won't be doing a FT86 type budget model, well not in NZ at least.
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby phoenix » Tue Jan 08, 2013 9:42 pm
uh?
i dont get it :P
He just worked it out...
phoenix
Postby rollaholic » Wed Jan 09, 2013 5:58 am
right, im behind the times on brz / 86 news. figured there had been something about an awd version.
:x
Postby Girvs » Wed Jan 09, 2013 8:02 am
Girvs
Postby Firefly_NZ » Sun Jan 13, 2013 10:41 pm
The fact that it's still being referred to as an FT86.... :roll:
Firefly_NZ
Postby NILPSI » Sun Jan 13, 2013 11:15 pm
Firefly_NZ wrote:The fact that it's still being referred to as an FT86.... :roll:
+1
2017 Triton - The "free supplied by work" daily
2018 Camry V6 - The actual daily
1997 Trueno BZ-G - The Garage Queen
1997 Supra SZ-R - Now with added boost!
NILPSI
Postby Grrrrrrr! » Sun Jan 13, 2013 11:47 pm
Picked up a NZ Driver mag from March 2010, and read about the 230kW+ FT86...
the joys of rumor.
Grrrrrrr!
Postby tiny2009 » Mon Jan 14, 2013 7:19 am
Only skim read the latest Top Gear magazine but there is mention of the BRZ having what felt like stiffer suspension (according to stig anyway). Could there be some subtle differences there?
tiny2009
Postby sergei » Mon Jan 14, 2013 8:38 am
tiny2009 wrote:Only skim read the latest Top Gear magazine but there is mention of the BRZ having what felt like stiffer suspension (according to stig anyway). Could there be some subtle differences there?
Maybe the STI version uses Bilstein shocks/springs and TRD version uses TRD/kyb(or whatever TRD is using)...
Postby Girvs » Mon Jan 14, 2013 9:03 am
If TRD is using the same shocks they did for the Supra, then factory were Bilsteins and TRD was just re-branded Bilsteins. Not sure if they have changed their setup since the 90's/early 2000's though :D
Girvs
