Powdercoating
Powdercoating
Postby FST4RD » Mon Feb 11, 2013 3:06 pm
Hey all, going all ratrod on the Starion, taking it back to bare metal.
Someone was telling me there is a clear powdercoat. Would this work and be suitable for all removable parts, ie bonnet, doors, headlight covers, front guards etc
Or is there something better, more durable I should use?
What will suit for the rest of the car, ie roof, rear guards etc that can't be removed? Cause I assume it would be able to be powdercoated?
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby d1 mule » Mon Feb 11, 2013 3:17 pm
if you can find a big enough oven im sure anything can be powder coated.
your $&#$% if you have any bog etc tho...
d1 mule
Postby FST4RD » Mon Feb 11, 2013 6:08 pm
d1 mule wrote:if you can find a big enough oven im sure anything can be powder coated.
Yeah thankfully there's no bog. Perhaps I'll skip doing the body parts
Is there a good product out there for this?
FST4RD
Postby moses » Mon Feb 11, 2013 6:08 pm
there is such a thing as clear powder coat ive used sever times over past few years it requires a lot of prep. I wouldn't be using it on panels personally as they are likely to warp being so thin with the heat of the oven the clear powder depending on brand can need a higher temp and a longer cook time
moses
Postby blindnz » Mon Feb 11, 2013 7:46 pm
Why not just clear coat? nice and thick. That way you could keep the rat look without rusting to much?
iOnic wrote:Don't take me too seriously - I own an MR2.
blindnz
Postby FST4RD » Mon Feb 11, 2013 7:52 pm
blindnz wrote:Why not just clear coat? nice and thick. That way you could keep the rat look without rusting to much?
That sounds like the plan now
Anyone have any recommendations?
Do I just take back to bare metal and then just spray the buggery out of it?
FST4RD
Postby blindnz » Mon Feb 11, 2013 10:28 pm
Not sure what's best. But I know some clear coats don't stick to bare metal that well.
Probably want a flat finish to, a gloss clear on a rat might look weird.
blindnz
Postby Dell'Orto » Mon Feb 11, 2013 11:21 pm
You might need to prep it with POR15 metal ready first, which gives it that funky bluey/yellowy streaky colour before clearing it
Postby DVSMOTORSPORT » Wed Feb 13, 2013 9:39 pm
Ive seen baremetal cleared a few times, but you need to get the right one, otherwise either the clear goes yellowish or the metal rusts underneath, I cant remember which one, looks fugly after about a year anyway.
Hi Im Ben, Have a nice day :)
DVSMOTORSPORT
