Info about light truck (12.5") wheels and gear ratios??
Postby Paulio » Fri Feb 08, 2013 9:30 pm
Hey guys happy friday
So i've got myself an ugly ass van with little back wheels, its one of those flat decks with no wheel arches in it and the floor is raised.. must be made for carrying big heavy things.
So the short of it is i want to change them for normal wheels, has anyone here done this before? i guess they will fit on sweet as? But will the gear ratios be ok? and how does one adjust the speedy so it reads the correct speed?
Any info appreciated cause im lost!
Paul
yees booy
Paulio
Postby fangsport » Fri Feb 08, 2013 11:09 pm
with standard road wheels fitted, the gearing will be quite tall, and hill starts could be a mare ?
fangsport
Postby Paulio » Fri Feb 08, 2013 11:17 pm
Yeah mate I know! The old fulla says it might just need a standard ratio diff to fix the 2 probs?
yees booy
Paulio
Postby macabre » Tue Feb 12, 2013 4:08 pm
Is it an L300?
237rwkw, all go no $&#$% show!
macabre
Postby Paulio » Tue Feb 12, 2013 4:17 pm
Yep delica p05v. I'm tempted to change the whole back end to standard because even the stud pattern for these little wheels is different
yees booy
Paulio
Postby macabre » Wed Feb 13, 2013 10:58 am
Well I could be keen on trying the diff in my l300, Its a turbo desiel model and its way too low geared. lemme know if you are getting rid of it
macabre
