strx7 wrote:i'd say they are from a St210 not a 215, the 2wd struts are longer and have wider bolt spacing - i'm applying 2wd vs 4wd 100 series corolla logic here but i'm pretty sure the same applies
strx7 wrote:could have also sent you the struts out of the wrong vehicle, it does happen from time to time.
$500 for a set of struts is up there price wise IMHO. I had a ST215 on the yard and someone wanted a set of struts i would have said $400-450.
Mr Revhead wrote:Bloody hell, $500 should pretty much get you new shocks.
BZG|Bling wrote:Mr Revhead wrote:Bloody hell, $500 should pretty much get you new shocks.
Yep $630 delivered according to sponsors section. Not really much of a saving when you consider brand new shocks vs 2nd hand unknowns.
BZG|Bling wrote:Yes it's shocks only. Can you just go new shocks + grab some standard top hats? I wouldn't have thought they would cost all that much. Someone likely has some hoarded.
BZG|Bling wrote:Lol, i'll remember not to bother posting next time.
Was just going on the blue spring you pulled out looking fine.
vr4boy wrote:I got some parts from him, found him bit pricey (but needed the part ASAP so had to use him) and when I picked up the guy that worked there pulling the parts off knew less about cars than my sister. And the owner wasn't a lot better.
