xsspeed wrote:Are you on oldschool? Check out kpr's thread there - albeit I think it was an NA motor that they slapped a j pipe on and turbo'd.
Was your safari originally NA? Keen to know what you have done tbh, my inlaws have an NA td42 patrol I would love to put a turbo on - I use it more than them at the moment for towing/launching the boat when my falcon wont suit, but would need to set something up with a variator pump (not the correct term but it escapes me right now)
diss7 wrote:Couldn't use a rb stock turbo, aren't they pretty much a t28 with a t3 flange?
QikStarlie wrote:yup as above, our truck runs a s5 ht18, with wastegate welded, runs about 15psi, comes on boost about 2k,
na pump is fine, unless you want much over 100kw at wheels. then you'll need to drop 2k or so to get a modified pump. afaik the turbo pump wont give you anymore fuel, just has a compensator, unless you find a gu pump, the are spose to have a slightly bigger plunger in them.
some stuff on it in link in my sig, or look it up on oldschool
xsspeed wrote:Is the aftermarket manifold anygood? or the j pipe route kpr originally took be just as good?
whats the gu pump you refer to kpr?
I wonder how cheaply I could achieve this on the in laws car
Lith wrote:Lol that dude is all about the Xanax. You have the Kinugawa on two of your cars now? How is it on the diesel?
~SlideWays~ wrote:I have an S13 project now, maybe it needs a Kinugawa turbo too?!![]()
Lith wrote:Lol, maybe! We have had a HEAP of issues with the internal wastegate actuator on my mates SR20 one though, one of the reasons I didn't have much issue with recommending an externally gated one for your 4AGE as the turbo itself has been a weapon - its hit around 300kw on E85 with it WANTING to run more due to the actuator, its hit near 2bar at just over 3000rpm on the SR! Not many <$1000 turbos will do 300kw and spool better than the stock T28, let alone also be reliable
Vertigo wrote:I have a T28-T3 adaptor if you want it, could open up your options a bit.
