GT86 Impressions.
Postby dnalunchie » Sat Jun 29, 2013 6:52 pm
iOnic wrote:Dunno what the stock block record is but I know of at least one 520hp stock block FA20 in a track car in the states.
Not that the strength really matters. If you're turbocharging, buy forged rods and pistons and do the appropriate mods.
wow really? stoke rods and pistons too?, I know of a couple 500+ hp ej20's stock internals in the UK
EX:89 RS and GT Legacys, 90 EF9 Civic, 95 Integra R, 95 AE101, 90 ST185, 88 Accord, 87 3rdoor and 5door Swift hatch, 91 Pontiac Lemans, 80 Liftback Celica, 95 Hornet 250
Current: 90 3sfe Corona
dnalunchie
Postby Bling » Sat Jun 29, 2013 6:52 pm
Lunchie are you comparing the suitability of NA engines to handle boost compared to engines designed to handle boost from the factory? Of course an engine not designed for boost is going to be less suitable for boost than a boosted engine.
Shit so much boost my head hurts.
Postby iOnic » Sat Jun 29, 2013 6:52 pm
That's what a stock block is.
Postby Lloyd » Sat Jun 29, 2013 6:55 pm
dnalunchie wrote:
Lloyd wrote:The EJ20s are hardly something you'd call reliable or economic by any stretch of the imagination.
Aren't the FAs running asymmetric conrods and things to get internals lighter while retaining strength, or is it for other reason?
Modern (2000+ single turbo) 2ltr ej20's are pretty reliable and no less economic than any other 90's 2ltr turbo.
Ummm.... an EJ20 designed with a turbo in mind isn't quite the same as a 2L N/A designed with fuel efficiency in mind, and then throwing a turbo on it.
Postby dnalunchie » Sat Jun 29, 2013 6:55 pm
iOnic wrote:That's what a stock block is.
Some people consider stock as in bore/stroke/ other internal strengthening
Also yes I know I am comparing apples and gorillas, I was more just asking Phil to elaborate on what he meant by the strength of the new subaru engines and defending the newer ej20's, should have made it clear they were two separate points.
Fairly pointless but I like playing devils advocate sometimes.
dnalunchie
Postby iOnic » Sat Jun 29, 2013 7:00 pm
Stock block = no mods to the block. Forged rods and pistons even with stock bore size /= stock block.
An N/A FA20 probably is stronger than an N/A EJ20.
Postby dnalunchie » Sat Jun 29, 2013 7:02 pm
iOnic wrote:Stock block = no mods to the block. Forged rods and pistons even with stock bore size /= stock block.
Didn't know that's what was the accepted explanation of stock block was, cheers for the info :)
dnalunchie
Postby Lloyd » Sat Jun 29, 2013 7:03 pm
Stock short block may be a better description
Postby RedMist » Sat Jun 29, 2013 8:24 pm
BZG|Bling wrote:Lunchie are you comparing the suitability of NA engines to handle boost compared to engines designed to handle boost from the factory? Of course an engine not designed for boost is going to be less suitable for boost than a boosted engine.
Actually...... I prefer my high compression stock Nissan VQ35 engine (with a bar of boost up it's arse), than my Cosworth VQ35 (with a bar of boost up it's arse) even with the Cosworth's 50 more whp. Throttle response and spool is better in a high compression engine with short duration cams.
And the stocker has been more reliable (Cosworth bearings don't like the slightest loss of oil pressure), the only issue being the rings/pistons aren't designed for boost, as such there is a reasonable amount of blowby.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby dnalunchie » Sat Jun 29, 2013 11:49 pm
Doesn't surprise me.
You take a highly focused athlete such as a long distance runner and they will be far more susceptible to muscle injury than your average joe blogs.
High performance usually = highly strung regardless of the application.
I remember driving a mates r33 GTS+T and its higher factory comp made it much nicer to drive off boost than a normal factory boosted 90's turbo
dnalunchie
Postby 2jayzgte » Mon Jul 01, 2013 8:08 pm
Harry Hard-out and not a turbo or super-charger in site.
http://www.speedhunters.com/2013/02/trd ... eight-six/
Best looking 86 going in my eyes I'll even go as far as saying its a work of art.
2jayzgte
Postby 1I1 » Mon Jul 01, 2013 8:42 pm
2jayzgte wrote:Harry Hard-out and not a turbo or super-charger in site.
Amen to that!
TRD Clicky >>Here
1I1
Postby tiny2009 » Mon Jul 01, 2013 9:52 pm
Spotted the new BRZ GT parked across the road at Rob Maetzig's place, looks great in blue. That guy gets to test some sweet cars, had the new M6 last month.
tiny2009
Postby dnalunchie » Mon Jul 01, 2013 10:03 pm
tiny2009 wrote:Spotted the new BRZ GT parked across the road at Rob Maetzig's place, looks great in blue. That guy gets to test some sweet cars, had the new M6 last month.
who/what is Rob Maetzig?
dnalunchie
Postby tiny2009 » Mon Jul 01, 2013 10:21 pm
Local motoring journalist guy, sorry I thought he might have been a bit more well known.
tiny2009
Postby Dorift 180 » Tue Jul 02, 2013 12:05 am
I really enjoy driving mine. No plans to get more power out of it either.
Is hugely entertaining. Just better rubber on it.
Making it faster would only increase the resulting accidents there would inevitably be.....
Convert ltd
Joe manji
Firestone Parnell/Wairau.
Dorift 180
Postby 2jayzgte » Tue Jul 02, 2013 8:20 am
Amen to that!
Mark I have no doubt that TRD will be drafting a whole lot of aftermarket parts for this car going off this Griffon project much like they have with the CCSR ISF car.If I was an 86 owner I'd be having a huge smile on my face.
Gotta love the CEO of Toyota and his love of racing as almost every car that seems to be a flag ship in its market gets the motor-sport treatment.I'm loving this guys thought process and hence why I still don't get why the first place people attack is under the bonnet.
2jayzgte
Postby Firefly_NZ » Fri Jul 05, 2013 10:51 pm
Dell'Orto wrote:Admittedly it had only done 50ks, but firefly's GT86 only made 96kw - thats less than some blacktop 4AGEs make, and a good hundred kg heavier.
FYI - (slightly) better news, re-run at 12,000kms, 96kW :arrow: 118kW
It also extrapolated the torque dip at 4,000rpm :?
Ultimately I absolutely love this car, especially hunting down Skylines around the corners (just to be smoked on the straights lol). But seriously, I love a car that I can drive at 100% all of the time!
Dorift 180: are you part of the 86/BRZ club?
Firefly_NZ
Postby slighty_looney » Fri Jul 05, 2013 10:57 pm
Thats a good power increase
FC3S
Robinson Steel Fabrications
Current Ride: 88 rx7
Project: viewtopic.php?t=88412
Discussion: viewtopic.php?t=88413
slighty_looney
Postby MR2SIK » Fri Jul 05, 2013 11:47 pm
Peak torque at 2600rpm? Didn't realise the 86 came as a diesel :lol:
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
