Leak!
Leak!
Postby drift-monkey » Thu Jul 18, 2013 11:00 pm
Found a leak under the car (1JZGE JZX90).
Not engine oil leak, it looks like a clear kinda thing, thought it was water at first but when I put water on it it went that funny purple blue colour like oil does. Checked out power steering and it wasn't leaking, checked brake fluid, not leaking. Anything else I'm missing?
Any help appreciated
drift-monkey
Postby Stott69 » Thu Jul 18, 2013 11:13 pm
Auto or manual?
Stott69
Postby drift-monkey » Thu Jul 18, 2013 11:19 pm
I could only ever dream of it being manual. Auto sadly, I checked the transmission fluid and it was pretty damn dark too, so I ruled that out as the culprit also.
Could it be fuel? Fuel line leaking somewhere? Or brake lines etc etc? It drips from the hole where the sump sits so its definitely in the engine bay.
drift-monkey
Postby Lloyd » Thu Jul 18, 2013 11:23 pm
From the firewall end or the other end? Could just be water from the aircon
Postby drift-monkey » Thu Jul 18, 2013 11:35 pm
Lloyd wrote:From the firewall end or the other end? Could just be water from the aircon
It's further forward. Does it leave marks or anything? This is leaving visible circle patch where it's leaked. Will jack it up tomorrow and give it a proper look..
drift-monkey
Postby Mr Revhead » Thu Jul 18, 2013 11:48 pm
Your flux capacitor is leaking!
Where in relation to car parts is it? Could be washer fluid if you just topped it up. How much is there?
Btw if your auto fluid is dark it's well past a change
Postby Lloyd » Thu Jul 18, 2013 11:57 pm
Toyota autos don't require fluid changes. Ever.
Edit - Pre-2000 anyway
Postby Stott69 » Fri Jul 19, 2013 12:02 am
Lloyd wrote:Toyota autos don't require fluid changes. Ever.
awww, that means my plan to have an excuse for manual will take for ever!
Air con should only leak water/condesation. If it seems to be working it wont be refrigirant oil.
Stott69
Postby Lloyd » Fri Jul 19, 2013 12:07 am
Stott69 wrote:Air con should only leak water/condesation. If it seems to be working it wont be refrigirant oil.
Am aware, but you wouldn't believe the number of people who come in for a water leak during summer... and say it's definitely not water. Just ruling it out ;)
Postby drift-monkey » Fri Jul 19, 2013 12:12 am
Mr Revhead wrote:Your flux capacitor is leaking!
Hahahahahah, I think I laughed more than I should have... I topped up my washer fluid with some dish washing liquid to make my windscreen smell nice. Aw man. Sorry bout this thread guys.
drift-monkey
Postby Lloyd » Fri Jul 19, 2013 12:45 am
Reminds me of a customer who thought he had a blown headgasket from the bubble showing up in the radiator. Turns out the washer fluid had been put in the radiator :lol:
Postby XS1V » Fri Jul 19, 2013 5:12 pm
drift-monkey wrote:I topped up my washer fluid with some dish washing liquid to make my windscreen smell nice. Aw man. Sorry bout this thread guys.
Hmm I wouldn't recommend this :?
A water leak running over an oily engine can do this, picks up some of the oil on its way through, or could just be water getting in and running over the engine etc. Have you smelt it? Normally a good give away on what fluid it is.
Brad
ST205 Group A Rallye #2363
XS1V
Postby TRDWGN » Fri Jul 19, 2013 6:44 pm
Not a leaking shock absorber? Had a leaky tein once that somehow ran onto the undertray so at first glance the leak appeared to be engine related
TRDWGN
Postby Mr Revhead » Fri Jul 19, 2013 6:55 pm
Um, case closed guys!
