allencr wrote:Looping is just adding another bypass.
If you want coolant bypassing the radiator AND don't have a marginal cooling system, do it.
How will it by-pass the radiator?
RomanV wrote:As someone who's driven a car without a heater for a while, sweet mother of god keep it in there.
Fogged up windows are the shittiest thing ever, why put in work now to make things harder for yourself later.
snwtoy wrote:Or if you do remove it, put a wire demister on the front window?
matt dunn wrote:snwtoy wrote:Or if you do remove it, put a wire demister on the front window?
the stick on ones are useless,
they slow a windscreen down from misting up,
but if they are already fogged up they wont do much.
Only the inbuilt ones are any good.
