Alternator physically smaller than a 4AFE one?
Postby Rick » Fri Aug 23, 2013 5:07 pm
I am after a physically smaller bodied (mostly the depth) alternator than a 4AFE one, but still keeping the same mounting points and pulley offset etc, Is there such a beast?
Postby matt dunn » Fri Aug 23, 2013 8:00 pm
4afe is double foot mount rather than the normal toyota type aren't they ?
Postby Rick » Fri Aug 23, 2013 11:48 pm
matt dunn wrote:4afe is double foot mount rather than the normal toyota type aren't they ?
Its like the one above
Postby Celica RA45 » Sat Aug 24, 2013 12:30 am
look at the dyhatsu charade 1s they are the smallest and will bolt up .im using 1 on my 3sge altezza
Celica RA45
Postby Rick » Sat Aug 24, 2013 1:43 am
Celica RA45 wrote:look at the dyhatsu charade 1s they are the smallest and will bolt up .im using 1 on my 3sge altezza
Oh great, any certain year or model etc?? do you happen to have a part number?
Postby Stu- » Sat Aug 24, 2013 11:21 am
Is a 1e unit smaller?
Project Thread
Stu-
Postby xsspeed » Sat Aug 24, 2013 11:33 am
I think the 1e and 2e ones are smaller than the 4age units, not sure re 4afe though
Postby matt dunn » Sat Aug 24, 2013 11:41 pm
2E ones are some of the smallest that have similar mounts,
but the spacing between the top and bottom mounts is smaller.
Can be made to fit though if you can adjust the top bracket.
I run them on my race car.
Postby Rick » Sun Aug 25, 2013 2:51 pm
matt dunn wrote:2E ones are some of the smallest that have similar mounts,
Sorry when you are saying "2E" are you talking about the 2E 1300cc Toyota motor?
Postby matt dunn » Sun Aug 25, 2013 8:08 pm
yes
Postby QikStarlie » Sun Aug 25, 2013 10:34 pm
was running one off a corona ST151 2S engine. they are the same as 2e alternator (55amp) but the plug is in a different location. will likely find this alot through the range, minor differences. so different part number.
2e will be a 4pk belt not a 5. but pulleys are a straight swap
QikStarlie
