hiace pissing out coolant problem
Postby Mike- » Tue Aug 27, 2013 7:04 pm
have a 93 hiace super gl
recently its started bubbling away when i stop (maybe bubbling when im driving) and pissing out coolant through the reservoir overflow.
Its not overheating, just sitting at mid temp all the time.
what the hells going on??
Mike-
Postby jacobrjett » Tue Aug 27, 2013 7:11 pm
possibly a faulty radiator cap?
they are supposed to relieve after a certain amount of pressure in the system to prevent hoses blowing off etc.
jacobrjett
Postby Dell'Orto » Tue Aug 27, 2013 7:19 pm
Possibly a cracked head?
Postby Mike- » Tue Aug 27, 2013 7:30 pm
arghhh i hope not, its my work van
Mike-
Postby Dell'Orto » Tue Aug 27, 2013 8:01 pm
2.8 diesel yeah?
Postby Mike- » Tue Aug 27, 2013 8:07 pm
yea the 3l
Mike-
Postby blindnz » Tue Aug 27, 2013 8:09 pm
BHG!$@&&$@% I miss MAGN1T
iOnic wrote:Don't take me too seriously - I own an MR2.
blindnz
Postby Boost_4_Life » Tue Aug 27, 2013 8:56 pm
I had exactly this issue with my old supercustom. It would drive fine but when i parked up and turned it off it would bubble up and blow coolant out the overflow. I had the radiator pressure checked and flushed, all fine. They suspected a cracked head so we used some chemi weld stuff as a temporary measure. Then a while later it started doing it again. I pulled the radiator out and found it was totally sludged up. Threw it away and got a new one, did water pump etc too and the problem went away.
So while a cracked head is possible, exhaust other avenues first, esp pull the radiator out and give it a decent flush.
'83 KP starlet rally car, 20v powa!
The rally beast
The rally beast again!
Boost_4_Life
Postby Dell'Orto » Tue Aug 27, 2013 9:13 pm
Yup definitely get the radiator cleaned out, if its really gunky a flush may not be enough
Postby Mike- » Tue Aug 27, 2013 10:42 pm
oh man, i $&#$% hate pulling out the radiator on these things. better than doing the head i spose
Mike-
Postby Dell'Orto » Tue Aug 27, 2013 10:45 pm
I think the head is easier tbh :lol:
Postby Mike- » Tue Aug 27, 2013 10:47 pm
stupid vans
Mike-
Postby Lloyd » Tue Aug 27, 2013 10:54 pm
Usually get the radiator done for warranty on the head anyway ;)
Postby allencr » Wed Aug 28, 2013 7:01 am
'Bubbling away' smells like steam & boiling coolant, or like what's coming out the exhaust pipe?
If it isn't overheating & puking out coolant & steam like a volcano, then the radiator work isn't going to do it any good.
HG time.
allencr
Postby Mike- » Wed Aug 28, 2013 10:26 pm
i replaced the thermostat and radiator cap this morning, and no more bubbling so far.
ill see how long it lasts
Mike-
Postby GDII » Thu Aug 29, 2013 9:29 am
Did the same on a diahatsu I had. Lasted for about 3 days then started again. Was a BHG in the end.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby Mike- » Sun Oct 13, 2013 4:22 pm
turns out the radiator was leaking and rotten as $&#$%.
replaced that and shes all good now
Mike-
Postby Boost_4_Life » Mon Oct 14, 2013 3:41 pm
Sweet good stuff :) Out of interest did the radiator have transmission cooling through the bottom? I've just assholed that setup on my new hiace and put an external trans cooler in. Best of both worls, decent cooling for the trans and stop pumping trans heat into the engine rad.
The rally beast
Boost_4_Life
