Mr Ree wrote:Just picked up my intake manifold from Bams, out in the Hutt.
The surfaces look alot nicer that they did when he picked it up from me.
Now I just need to cut away a small section of the TB flange as the Q45 throttle body has a small arm that fouls on it when the throttle is opened.
Does anybody know who makes good custom length throttle cables in the Welly area? Thanks
Had an idea of using a nut and bolt combo - a cut down the center and having the flanges of the nut crimp the cable.
Scottie wrote:BMW?
touge_ae101 wrote:
also was a good chance to take new van for a good run. towed the trailer like a dream can't wait for long trips with racecar(s) in tow! suprisingly handles awesome with bilsteins all round.. need to get LSD serviced as it picks up an inside wheel too easily when thrashing it.. also needs intercooler/more boost...good fun on the gravel though!!
touge_ae101 wrote:also was a good chance to take new van for a good run. towed the trailer like a dream can't wait for long trips with racecar(s) in tow! suprisingly handles awesome with bilsteins all round.. need to get LSD serviced as it picks up an inside wheel too easily when thrashing it.. also needs intercooler/more boost...good fun on the gravel though!!
Sakte board wheel bearings fit in the gearbox end of the shift cable.GDII wrote:Figured out why I thought I had worn syncros in the MR2. The bushes on the gear linkages on the gearbox are worn so the cables were loose. Wrapped the pins on the gearbox selector forks with insulation tape as a temp fix. Worked great, much more positive gear change and I no longer struggle to select 1 through 3. Especially 3rd to 2nd at speeds around 60-70kph.
Adoom wrote:The downside to a fast car that looks slow: Vans and 4X4s pull out in front of me at over taking lanes, then they use THE WHOLE passing lane to pass one(or less) cars
rollaholic wrote:Adoom wrote:The downside to a fast car that looks slow: Vans and 4X4s pull out in front of me at over taking lanes, then they use THE WHOLE passing lane to pass one(or less) cars
i dont think this phenomenon is limited to fast cars that look slow. i imagine on lamborghini forums they complain that people pull out in front of them too. its just a combination of being a bit selfish and alot oblivious.
85AW20v wrote:Sakte board wheel bearings fit in the gearbox end of the shift cable.
