How much does a turbo weigh?
Postby Grrrrrrr! » Sat Sep 28, 2013 6:47 pm
Thinking about bringing a turbo back from Oz in a few months and wondering how much a turbo weighs? I just don't happen to have one lying about to weigh atm. If its <10kg I figure I can take some older clothing and ditch it before I fly back to save AUD$120 in excess baggage thievery.
Grrrrrrr!
Postby Stott69 » Sat Sep 28, 2013 7:05 pm
Will depend on turbo, the one I took off the car is lots lighter than the new one
Stott69
Postby Elmo » Sat Sep 28, 2013 7:10 pm
VGT turbo from a 600 signature is about 50kg (at a guess)
Elmo
Postby Grrrrrrr! » Sat Sep 28, 2013 7:27 pm
So your 60-1 which the turbonetics website says is 15-20lbs was heavier than the Std turbo... guess a td05 should be in a similar ballpark then, plus weight of fittings/hoses etc. Will have to take the old steelcaps etc and ditch them before I return but should be doable.
Grrrrrrr!
Postby iOnic » Sat Sep 28, 2013 7:29 pm
I can weigh a td05hr/a if you want. Got a few.
Postby Grrrrrrr! » Sat Sep 28, 2013 7:44 pm
Chur, that would be good man. Can preweigh and make sure its going to be under 23kgs.
Grrrrrrr!
Postby iOnic » Sat Sep 28, 2013 8:02 pm
Definitely is under that. My T88 weighs just on 15kg
Postby Stott69 » Sat Sep 28, 2013 8:45 pm
Grrrrrrr! wrote:So your 60-1 which the turbonetics website says is 15-20lbs was heavier than the Std turbo... guess a td05 should be in a similar ballpark then, plus weight of fittings/hoses etc. Will have to take the old steelcaps etc and ditch them before I return but should be doable.
Wasnt a standard, DSR430 slug. Still have the DSR at the mo if that weight suits your needs.
Stott69
Postby phoenix » Sat Sep 28, 2013 10:13 pm
Just fashion it into a hat and save the luggage space.
phoenix
Postby Bling » Sat Sep 28, 2013 10:15 pm
Glad it wasn't just me that thought of that :lol:
Postby rollaholic » Sat Sep 28, 2013 10:18 pm
iOnic wrote:My T88
wtb pics of t88 on rb30
Postby Lith » Sun Sep 29, 2013 10:24 am
Atpturbo provide shipping weights for all of their turbos, which could give an idea of what you could expect : http://www.atpturbo.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=tp&Category_Code=GRT
2007 Mazdaspeed Axela
Lith
Postby Jdawg » Sun Sep 29, 2013 12:41 pm
You can buy extra luggage allowance before you go.
Cost me NZ$60 for 40kg when I bought back a Commodore brake kit for the HZ = 20kg per side.
I went over in the clothes I was wearing and bought new clothes over there on my first day.
Jdawg
Postby spoonza6 » Sun Sep 29, 2013 2:03 pm
Careful they might classify it as a dg n won't be allowed in checked luggage
spoonza6
Postby Grrrrrrr! » Sun Sep 29, 2013 2:22 pm
Lol, good one :roll:
Grrrrrrr!
Postby thegreatestben » Sun Sep 29, 2013 8:40 pm
They almost didn't let me take a kingchrome socket set onto a domestic flight in my backpack, worried I'd take the plane apart midflight bahaha
thegreatestben
Postby iOnic » Mon Sep 30, 2013 7:38 am
Near as makes no difference to 10kg. Td05hra 16g with titanium compressor and 10.5cm rear housing.
Postby CAMB01 » Mon Sep 30, 2013 9:21 pm
Friend of mine couldnt take some of his tools over to Aussie with him as he needed them for his job. They wouldnt allow them on board.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Grrrrrrr! » Mon Sep 30, 2013 10:05 pm
Carry on is a no-go, checked should be fine. I've personally taken pinions, shims, hand tools, battery drills, various bearings, drill sets to Oz with no problem in checked luggage. Most trouble I had was with the shims and pinions, 28kg box of tightly packed stainless steel and high strength plastic gears. They xrayed it 5 times but they still couldn't see much, asked me what it was and seemed happy enough to let it fly once I told them.
I've actually been surprised at what I have got through security in carry on. had a couple of smallish screwdrivers in my laptop bag I'd forgotten about, and they had no problem with that. Would've been most useful if I'd wanted to stab someone..
Grrrrrrr!
Postby CAMB01 » Tue Oct 01, 2013 12:13 am
These were large 3/4 sockets etc. He's a diesel mechanic.
CAMB01
