Kiwi-Corolla wrote:First thing I'd do is a compression test. If you're down on compression then your performance will be less than ideal to begin with. Ideally you'll have 193psi or more per cylinder, however depending on how the engine has been treated you may see between 150-180psi (or less if the rings are worn). Most compression gauges aren't very accurate anyway, unless you spend decent money on a quality one, but the thing you need to worry about is that you don't get more than 14psi difference between each cylinder. If you're getting under 156psi and/or more than 14psi difference per cylinder then a rebuild or replacement would be your best bet, as any performance mods you make are still likely to yield less power than factory if your motor isn't up to scratch.
If your engine is up to scratch however, a few good mods would be an aftermarket 4-2-1 header set (especially replacing the 2-1 section that goes over the subframe as this is VERY restrictive from factory), a cold air intake or high flow panel filter in the factory airbox with better ducting, and an adjustable fuel pressure regulator (increasing the fuel pressure by as little as 4psi makes a big difference in mid-range performance).
Aside from that, unless you plan to whack some bigger cams in etc, another thing you could look at would be a lightweight flywheel and weight reduction - But, as mentioned earlier, check the health of the engine first before even bothering with performance mods or else it's essentially money down the drain.
touge_ae101 wrote:a blacktop without cams won't make more than 105kw atw. there are big gains to be made with some big cams and good compression.
really depends what extent you want to go to.. Engine in ae82 is still completely standard with ST rods, standard pistons, uprated valve springs and a big cam. it's a pretty simple recipe and makes 134kw atw..
Definitely a Link and a good tune makes a huge difference to a standard engine but look to replace the valve springs and rods with ST ones if you're planning on making more than 105kw.. in saying that though I never had a blacktop throw a rod out the side of a block and I drove them relatively hard.
Bling wrote:Congrats on the bonus 1kw Ben. Obviously dynos will read different, and every engine is different.
What is the budget for the upgrades? I'd focus on getting it running right before worrying about upgrades though. Hopefully it's an easy fix to get it sorted.
Lloyd wrote:They do throw rods, and they do stretch valves if you're looking for more revs.
VirtualWolf wrote:To be honest it seems to be running terribly at the moment... ...only... ...thing i can think of is maybe a CAI system. Any ideas or tips?
captain crescent wrote:Or buy this viewtopic.php?t=91327
Its a Toyota not quite the same output as a type r but fun all the same.....
dnalunchie wrote:captain crescent wrote:Or buy this viewtopic.php?t=91327
do you know what the output is? ie dynoed? also fwiw that is a NICE runx, glws
captain crescent wrote:dnalunchie wrote:captain crescent wrote:Or buy this viewtopic.php?t=91327
It made 116 kw atw
allencr wrote:What"s the compression, ?VirtualWolf wrote:To be honest it seems to be running terribly at the moment... ...only... ...thing i can think of is maybe a CAI system. Any ideas or tips?
What does terribly mean?
What"s the compression, how many miles/kilometers, what does it look like when the oil and radiator cap are removed and do you just want bling bolt-ons & hasten its death or a more then decent DD?
Users browsing this forum: Google [Bot] and 41 guests
